Ga door naar hoofdinhoud
Nintendo GameCube Controller Buttons Replacement
Wat je nodig hebt
  1. Nintendo GameCube Controller Buttons Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo GameCube Controller Buttons Replacement: stap 2, afbeelding 1 van 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo GameCube Controller Buttons Replacement, Z Button: stap 3, afbeelding 1 van 2 Nintendo GameCube Controller Buttons Replacement, Z Button: stap 3, afbeelding 2 van 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    Vraag FixBot
    Voeg opmerking toe
  4. Nintendo GameCube Controller Buttons Replacement, Circuit Board: stap 4, afbeelding 1 van 1
    • Carefully unhook the cable that is looped around the peg.
    Vraag FixBot
    Voeg opmerking toe
  5. Nintendo GameCube Controller Buttons Replacement: stap 5, afbeelding 1 van 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    Vraag FixBot
    Voeg opmerking toe
  6. Nintendo GameCube Controller Buttons Replacement, Buttons: stap 6, afbeelding 1 van 2 Nintendo GameCube Controller Buttons Replacement, Buttons: stap 6, afbeelding 2 van 2
    • Remove the rubber backing that covers the buttons.
    Vraag FixBot
    Voeg opmerking toe
  7. Nintendo GameCube Controller Buttons Replacement: stap 7, afbeelding 1 van 3 Nintendo GameCube Controller Buttons Replacement: stap 7, afbeelding 2 van 3 Nintendo GameCube Controller Buttons Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use tweezers to lift buttons out of their sockets.
    • When putting the buttons back, make sure the slots properly fit back together.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
20 andere personen hebben deze handleiding voltooid.
Sean Michel
2.750 Reputatie
8 handleidingen geschreven
Cal Poly, Team 19-44, Regan Winter 2013 Lid van Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Leden
34 handleidingen geschreven
3Gids Commentaar
Is there a way I can buy the buttons separably? I lost a the X button and it's gone missing and i wanna buy one :(
tp4yourbunghole - Antwoord Deel
u can either get a 2 dollar full button set on ebay by searching ngc buttons or u can buy from battle beaver customs for 1 dollar
dariuscorrfz - Antwoord Deel
How do you put the back back on?
Steven Enns - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 196
Altijd: 32,982
