Ga door naar hoofdinhoud
Nintendo Game Boy Advance SP Brightness Switch Replacement
Wat je nodig hebt
  1. Nintendo Game Boy Advance SP Brightness Switch Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Brightness Switch Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Brightness Switch Replacement: stap 3, afbeelding 1 van 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Brightness Switch Replacement, Back Cover: stap 4, afbeelding 1 van 2 Nintendo Game Boy Advance SP Brightness Switch Replacement, Back Cover: stap 4, afbeelding 2 van 2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Brightness Switch Replacement: stap 5, afbeelding 1 van 1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Brightness Switch Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
  7. Nintendo Game Boy Advance SP Brightness Switch Replacement: stap 7, afbeelding 1 van 1
    • Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
    • Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
  8. Nintendo Game Boy Advance SP Brightness Switch Replacement, Brightness Switch: stap 8, afbeelding 1 van 1
    • With your fingers, lift the track pad out off the brightness switch.
    • Keep the track pad clean. A dirty or dusty track pad will lead to the brightness switch not working when you press it.
  9. Nintendo Game Boy Advance SP Brightness Switch Replacement: stap 9, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers, lift the brightness switch out of the Game Boy Advance SP.
Conclusie
15 andere personen hebben deze handleiding voltooid.
DJ Pantone
1.938 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-22, Forte Winter 2013 Lid van Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Leden
41 handleidingen geschreven
Één opmerking
Thank you so much
sherzadcemil - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 123
Altijd: 20,201
