Ga door naar hoofdinhoud
Nintendo Entertainment System Disassembly
Wat je nodig hebt
    1. Nintendo Entertainment System Disassembly, Remove Top Housing: stap 1, afbeelding 1 van 2 Nintendo Entertainment System Disassembly, Remove Top Housing: stap 1, afbeelding 2 van 2
      • Remove six 13.25mm Phillips screws on the bottom of the system.
      • The screws are recessed about 40mm.
      • Once all screws are removed, simply lift the bottom half away from the top housing.
      Vraag FixBot
      Voeg opmerking toe
    2. Nintendo Entertainment System Disassembly, Remove Top RF Shield: stap 2, afbeelding 1 van 3 Nintendo Entertainment System Disassembly, Remove Top RF Shield: stap 2, afbeelding 2 van 3 Nintendo Entertainment System Disassembly, Remove Top RF Shield: stap 2, afbeelding 3 van 3
      • Remove seven 13.25mm Phillips screws around the perimeter of the RF shield.
      • Lift the RF shield up and away from the system and place aside.
      Vraag FixBot
      Voeg opmerking toe
    3. Nintendo Entertainment System Disassembly, Remove Cartridge Tray: stap 3, afbeelding 1 van 3 Nintendo Entertainment System Disassembly, Remove Cartridge Tray: stap 3, afbeelding 2 van 3 Nintendo Entertainment System Disassembly, Remove Cartridge Tray: stap 3, afbeelding 3 van 3
      • Remove four 13.25mm Phillips screws from the four corners of the cartridge tray.
      • Your system may only have two screws on the bottom.
      • Remove two 17.25mm Phillips screws from the top of cartridge tray.
      • Once free, slide the cartridge tray towards you and then lift slightly in the front to remove.
      Vraag FixBot
      Voeg opmerking toe
    4. Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 1: stap 4, afbeelding 1 van 3 Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 1: stap 4, afbeelding 2 van 3 Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 1: stap 4, afbeelding 3 van 3
      • Remove three 13.25mm Phillips screws to free the motherboard from the bottom housing.
      • Carefully lift the motherboard and turn it over to find the wired connections.
      Vraag FixBot
      Voeg opmerking toe
    5. Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 2: stap 5, afbeelding 1 van 2 Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 2: stap 5, afbeelding 2 van 2
      • Disconnect the wired connections from the motherboard.
      • Player 1 (Shorter wires)
      • Player 2 (Longer wires)
      • Power/Reset Buttons
      Vraag FixBot
      Voeg opmerking toe
    6. Nintendo Entertainment System Disassembly, Remove Bottom RF Shield: stap 6, afbeelding 1 van 2 Nintendo Entertainment System Disassembly, Remove Bottom RF Shield: stap 6, afbeelding 2 van 2
      • The bottom RF shield is held on by tension around the expansion port. Lift the shield up and away from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    7. Nintendo Entertainment System Disassembly, Remove 72-Pin Connector: stap 7, afbeelding 1 van 2 Nintendo Entertainment System Disassembly, Remove 72-Pin Connector: stap 7, afbeelding 2 van 2
      • To remove the 72-Pin connector, apply force to each edge and slide the connector off the contacts on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    8. Nintendo Entertainment System Disassembly, Remove Power/Reset Buttons: stap 8, afbeelding 1 van 2 Nintendo Entertainment System Disassembly, Remove Power/Reset Buttons: stap 8, afbeelding 2 van 2
      • Remove two 13.25mm Phillips screws from the button assembly. Lift slightly in the back and then up and away from the housing to remove.
      Vraag FixBot
      Voeg opmerking toe
    9. Nintendo Entertainment System Disassembly, Remove Controller Ports: stap 9, afbeelding 1 van 3 Nintendo Entertainment System Disassembly, Remove Controller Ports: stap 9, afbeelding 2 van 3 Nintendo Entertainment System Disassembly, Remove Controller Ports: stap 9, afbeelding 3 van 3
      • Remove two 7.25mm Phillips screws from the bottom of the system. Lift the controller port faceplate up and away.
      • Remove the controller ports by feeding them through the port holes to the front of the housing.
      • When reassembling, Player 1 (Left) has shorter wires that Player 2 (Right).
      Vraag FixBot
      Voeg opmerking toe
    10. Nintendo Entertainment System Disassembly, Remove Plastic Door and Accent Pieces: stap 10, afbeelding 1 van 3 Nintendo Entertainment System Disassembly, Remove Plastic Door and Accent Pieces: stap 10, afbeelding 2 van 3 Nintendo Entertainment System Disassembly, Remove Plastic Door and Accent Pieces: stap 10, afbeelding 3 van 3
      • Remove seven 7.25mm small flathead screws from the inside of the top housing.
      • Two of these screws also hold a spring for the door. When reassembling, refer to the keyed shape of the plastic to orient these correctly.
      Vraag FixBot
      Voeg opmerking toe
    11. Nintendo Entertainment System Disassembly, Disassembly Complete!: stap 11, afbeelding 1 van 2 Nintendo Entertainment System Disassembly, Disassembly Complete!: stap 11, afbeelding 2 van 2
      • Screw List
      • (19x) 13.25mm Phillips
      • (2x) 17.25mm Phillips
      • (2x) 7.25mm Phillips (Silver, large cap)
      • (7x) 7.25mm Flathead (Silver, small)
      Vraag FixBot
      Voeg opmerking toe
Conclusie
27 andere personen hebben deze handleiding voltooid.
Joe Shacar
1.345 Reputatie
1 Handleiding geschreven
6Gids Commentaar
Thank you very much!
Haihatsu - Antwoord Deel
Love step by step
Rene Leon - Antwoord Deel
Very well done easy to do and easier to follow.
rictic1 - Antwoord Deel
Perfect just top style
SYNTAX - Antwoord Deel
Great guide, I wanted to confirm that I had the right screws on me since I had disassembled my NES on a workbench with some other consoles (bad habit).
I thought I was going crazy though since the 13.25mm Phillips screw count is off- it's 20 if you have 2 screws on your cartridge tray, and 22 if you have the 6 screws shown in the guide.
- 6x outer casing
- 7x top RF shield
- 2x or 4x cartridge tray
- 3x lower motherboard
- 2x power/reset button assembly
Dylan French - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 23
Afgelopen 7 dagen: 167
Afgelopen 30 dagen: 860
Altijd: 37,869
