Ga door naar hoofdinhoud
Nintendo Entertainment System Controller Maintenance
Wat je nodig hebt
  1. Nintendo Entertainment System Controller Maintenance, Nintendo Entertainment System Controller Maintenance: stap 1, afbeelding 1 van 1
    • Unscrew the six 13 mm screws with the Philips screwdriver.
  2. Nintendo Entertainment System Controller Maintenance: stap 2, afbeelding 1 van 1
    • Lift the controller back plate straight off of the controller then set aside.
  3. Nintendo Entertainment System Controller Maintenance: stap 3, afbeelding 1 van 1
    • Unwind the cable from plastic poles.
  4. Nintendo Entertainment System Controller Maintenance: stap 4, afbeelding 1 van 1
    • Gently remove the circuit board from the controller face. Use a non marring object to lever up board if it is stuck.
  5. Nintendo Entertainment System Controller Maintenance: stap 5, afbeelding 1 van 1
    • Remove the indicated rubber pads.
  6. Nintendo Entertainment System Controller Maintenance: stap 6, afbeelding 1 van 1
    • Remove all plastic buttons. Clean the buttons and controller with soap and water.
  7. Nintendo Entertainment System Controller Maintenance: stap 7, afbeelding 1 van 1
    • Inspect each rubber pad for tears or cracks and making note of any tears.
  8. Nintendo Entertainment System Controller Maintenance: stap 8, afbeelding 1 van 1
    • Clean all pads with rubbing alcohol; focus on cleaning the black conductive circles on the underside of the pads.
  9. Nintendo Entertainment System Controller Maintenance: stap 9, afbeelding 1 van 1
    • Once clean, apply thin layers of rubber cement to any deformation. Allow cement to dry and apply multiple layers as needed. Do not over apply rubber cement as it can cause the pads to warp as it dries.
  10. Nintendo Entertainment System Controller Maintenance: stap 10, afbeelding 1 van 1
    • Inspect all solder points for loose connections.
  11. Nintendo Entertainment System Controller Maintenance: stap 11, afbeelding 1 van 1
    • Clean the input contacts with 91% Isopropyl Alcohol on a Q-tip
  12. Nintendo Entertainment System Controller Maintenance: stap 12, afbeelding 1 van 1
    • Read the iFixit soldering guide and do not attempt this step if you are not confidant in your ability to do so safely.
    • Ensure that all 91% isopropyl alcohol has evaporated. If necessary perform any soldering away from the area in which you cleaned the controller.
    • Re-solder any loose wires on the circuit board.
  13. Nintendo Entertainment System Controller Maintenance: stap 13, afbeelding 1 van 1
    • Allow any recently soldered points to cool back to room temperature before performing this step.
    • Glue the cord onto the circuit board to prevent future loosening of the wires.
    • Leave slack on both sides and allow glue to harden.
  14. Nintendo Entertainment System Controller Maintenance: stap 14, afbeelding 1 van 1
    • Reverse steps from 6 through to 2 to reassemble controller.
    • Before replacing screws make sure the controller back fits tightly to the controller face.
    • If needed trim excess glue from around the cord to ensure a good fit.
  15. Nintendo Entertainment System Controller Maintenance: stap 15, afbeelding 1 van 1
    • Plug in your repaired controller and try all buttons and actions to test controller function and responsiveness
Conclusie
Thank you for using our step by step controller guide. Enjoy your NES games!
If the controller isn’t working after this guide, re-check the soldering points, and redo as necessary. If this still doesn’t fix the controller you may have to get a new wire.
6 andere personen hebben deze handleiding voltooid.
Andrew Churchill
210 Reputatie
1 Handleiding geschreven
Colorado Springs, Team 1-6, Mcmichael Fall 2015 Lid van Colorado Springs, Team 1-6, Mcmichael Fall 2015
UCCS-MCMICHAEL-F15S1G6
2 Leden
2 handleidingen geschreven
Één opmerking
Hi There,
Just wondering if you knew “where” I could purchase a special set of silicone buttons for a wireless Nintendo NES controller? The buttons are sticking and when I remove the cover, the silicone buttons were stripped and no longer functional. I know how to replace all of the parts - just not sure where I can actually find the part that I need.
I am not sure if you know what the “NES wireless controller” looks like “internally” but it has 4 buttons together - not just 2 like the original NES controller. The silicone button assembly looks very similar to the silicone button assembly of the “controller buttons” portion (or the arrows portion that actually allows you to “move” when playing a game.
Any assistance you could provide for me to find the right part to fix my son’s controller would be GREATLY APPRECIATED !!
Thank you
Jeff
Jeff L - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 122
Altijd: 9,806
