Ga door naar hoofdinhoud
Nintendo Entertainment System Controller Cable Replacement
Wat je nodig hebt
  1. Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: stap 1, afbeelding 1 van 2 Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: stap 1, afbeelding 2 van 2
    • Remove the 6 8mm screws in the back cover using a #1 Philips screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo Entertainment System Controller Cable Replacement, Loosen Cable: stap 2, afbeelding 1 van 1
    • Lift the back cover off the controller.
    • Remove the cable from its holders to facilitate PCB removal.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo Entertainment System Controller Cable Replacement, PCB Removal: stap 3, afbeelding 1 van 1
    • Lift the PCB straight up and out of the controller. Turn the board over to access the solder joints for the cable.
    • Desolder the 5 connections and solder in your new cable.
    • Wire colors are printed on the reverse side of the board.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
themap504
80 Reputatie
1 Handleiding geschreven
2Gids Commentaar
My replacement plugs have different colors. Colors are yellow, white, red, black, and green. I’m also doing a max controller not regular nes controller. The max has yellow, red, white, red, and orange color schemes. Any advice. I wired up same colors and guessed for rest. figured black could replace one of the reds, and used green to replace orange, but console just resets over and over with that controller plugged in.
Daniel Melvin - Antwoord Deel
Check for continuity from the pins on the plug side with the wires and soldier them in the corresponding spot, i:e if red is power then you soldier it to the power slot on the motherboard and so on. Check if you can find a instruction book on the controller.
Cgull - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 62
Altijd: 3,113
