Ga door naar hoofdinhoud
Nintendo DSi XL Power Board Replacement
Wat je nodig hebt
  1. Nintendo DSi XL Power Board Replacement, Battery: stap 1, afbeelding 1 van 2 Nintendo DSi XL Power Board Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo DSi XL Power Board Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery from the DSi XL.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo DSi XL Power Board Replacement, Lower Case: stap 3, afbeelding 1 van 3 Nintendo DSi XL Power Board Replacement, Lower Case: stap 3, afbeelding 2 van 3 Nintendo DSi XL Power Board Replacement, Lower Case: stap 3, afbeelding 3 van 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
    Vraag FixBot
    Voeg opmerking toe
  4. Nintendo DSi XL Power Board Replacement: stap 4, afbeelding 1 van 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
    Vraag FixBot
    Voeg opmerking toe
  5. Nintendo DSi XL Power Board Replacement: stap 5, afbeelding 1 van 3 Nintendo DSi XL Power Board Replacement: stap 5, afbeelding 2 van 3 Nintendo DSi XL Power Board Replacement: stap 5, afbeelding 3 van 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
    Vraag FixBot
    Voeg opmerking toe
  6. Nintendo DSi XL Power Board Replacement: stap 6, afbeelding 1 van 2 Nintendo DSi XL Power Board Replacement: stap 6, afbeelding 2 van 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Nintendo DSi XL Power Board Replacement: stap 7, afbeelding 1 van 2 Nintendo DSi XL Power Board Replacement: stap 7, afbeelding 2 van 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
    Vraag FixBot
    Voeg opmerking toe
  8. Nintendo DSi XL Power Board Replacement, Power Board: stap 8, afbeelding 1 van 2 Nintendo DSi XL Power Board Replacement, Power Board: stap 8, afbeelding 2 van 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
    • With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  9. Nintendo DSi XL Power Board Replacement: stap 9, afbeelding 1 van 1
    • Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
    • Use caution, as the wires are very fragile and could come out of the connector if pulled on too hard.
    Vraag FixBot
    Voeg opmerking toe
  10. Nintendo DSi XL Power Board Replacement: stap 10, afbeelding 1 van 2 Nintendo DSi XL Power Board Replacement: stap 10, afbeelding 2 van 2
    • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
    • Lift the power board off the upper case.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
8 andere personen hebben deze handleiding voltooid.
Brett Hartt
132.210 Reputatie
144 handleidingen geschreven
iFixit Lid van iFixit
Staff
122 Leden
27.484 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 149
Altijd: 19,370
