Ga door naar hoofdinhoud
Nintendo DS Bottom LCD Screen Replacement
Wat je nodig hebt
  1. Nintendo DS Bottom LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 3 Nintendo DS Bottom LCD Screen Replacement, Battery: stap 1, afbeelding 2 van 3 Nintendo DS Bottom LCD Screen Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo DS Bottom LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo DS Bottom LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from the Nintendo DS.
    Vraag FixBot
    Voeg opmerking toe
  4. Nintendo DS Bottom LCD Screen Replacement, Back Panel: stap 4, afbeelding 1 van 1
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
    Vraag FixBot
    Voeg opmerking toe
  5. Nintendo DS Bottom LCD Screen Replacement: stap 5, afbeelding 1 van 3 Nintendo DS Bottom LCD Screen Replacement: stap 5, afbeelding 2 van 3 Nintendo DS Bottom LCD Screen Replacement: stap 5, afbeelding 3 van 3
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
    Vraag FixBot
    Voeg opmerking toe
  6. Nintendo DS Bottom LCD Screen Replacement, Motherboard replacement.: stap 6, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
    Vraag FixBot
    Voeg opmerking toe
  7. Nintendo DS Bottom LCD Screen Replacement: stap 7, afbeelding 1 van 3 Nintendo DS Bottom LCD Screen Replacement: stap 7, afbeelding 2 van 3 Nintendo DS Bottom LCD Screen Replacement: stap 7, afbeelding 3 van 3
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
    Vraag FixBot
    Voeg opmerking toe
  8. Nintendo DS Bottom LCD Screen Replacement: stap 8, afbeelding 1 van 2 Nintendo DS Bottom LCD Screen Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
    Vraag FixBot
    Voeg opmerking toe
  9. Nintendo DS Bottom LCD Screen Replacement: stap 9, afbeelding 1 van 2 Nintendo DS Bottom LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
    Vraag FixBot
    Voeg opmerking toe
  10. Nintendo DS Bottom LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
    Vraag FixBot
    Voeg opmerking toe
  11. Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: stap 11, afbeelding 1 van 2 Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: stap 11, afbeelding 2 van 2
    • Peel off the black cushion foam on the bottom touch screen to expose the ribbon cable.
    • Gently lift the screen out of the base.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
23 andere personen hebben deze handleiding voltooid.
dnguye26
758 Reputatie
4 handleidingen geschreven
Cal Poly, Team 18-3, Maness Fall 2009 Lid van Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Leden
31 handleidingen geschreven
2Gids Commentaar
I like it but add a step 12 maybe, to see how to put in a new screen.
Zackary Benton - Antwoord Deel
Why was this unfinished guide published?
Or was it just mistitled?
"How to 'almost' remove the lower screen"
mgoerlich1990 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 108
Afgelopen 30 dagen: 503
Altijd: 52,350
