Ga door naar hoofdinhoud
Nintendo 3DS XL Microphone Replacement
Wat je nodig hebt
  1. Nintendo 3DS XL Microphone Replacement, Remove the back cover screws: stap 1, afbeelding 1 van 1
    • Use a JIS 00 screwdriver to loosen the 4.2 mm‑long screws on the top edge of the back cover.
    • The screws have locking washers that prevent the screws from falling out. Keep these in place.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo 3DS XL Microphone Replacement, Remove the back cover: stap 2, afbeelding 1 van 2 Nintendo 3DS XL Microphone Replacement, Remove the back cover: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to pry off the clips securing the back cover, starting at the top corners and working your way down.
    • Use your hands to keep the clips from reattaching.
    • Use your hands to remove the back cover.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo 3DS XL Microphone Replacement: stap 3, afbeelding 1 van 3 Nintendo 3DS XL Microphone Replacement: stap 3, afbeelding 2 van 3 Nintendo 3DS XL Microphone Replacement: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry the battery out of its recess and remove it.
    Vraag FixBot
    Voeg opmerking toe
  4. Nintendo 3DS XL Microphone Replacement, Microphone: stap 4, afbeelding 1 van 2 Nintendo 3DS XL Microphone Replacement, Microphone: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
    Vraag FixBot
    Voeg opmerking toe
  5. Nintendo 3DS XL Microphone Replacement: stap 5, afbeelding 1 van 2 Nintendo 3DS XL Microphone Replacement: stap 5, afbeelding 2 van 2
    • Remove the six 6.2 mm screws using a Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. Nintendo 3DS XL Microphone Replacement: stap 6, afbeelding 1 van 1
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. Nintendo 3DS XL Microphone Replacement: stap 7, afbeelding 1 van 3 Nintendo 3DS XL Microphone Replacement: stap 7, afbeelding 2 van 3 Nintendo 3DS XL Microphone Replacement: stap 7, afbeelding 3 van 3
    • With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
    Vraag FixBot
    Voeg opmerking toe
  8. Nintendo 3DS XL Microphone Replacement: stap 8, afbeelding 1 van 3 Nintendo 3DS XL Microphone Replacement: stap 8, afbeelding 2 van 3 Nintendo 3DS XL Microphone Replacement: stap 8, afbeelding 3 van 3
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the lower case from the rest of the device and set aside.
    Vraag FixBot
    Voeg opmerking toe
  9. Nintendo 3DS XL Microphone Replacement: stap 9, afbeelding 1 van 3 Nintendo 3DS XL Microphone Replacement: stap 9, afbeelding 2 van 3 Nintendo 3DS XL Microphone Replacement: stap 9, afbeelding 3 van 3
    • Position the device such that the game cartridge slot is located at the top.
    • Locate the microphone in the bottom left corner.
    • Using tweezers remove the microphone.
    • There will be a ribbon that connects the microphone to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  10. Nintendo 3DS XL Microphone Replacement: stap 10, afbeelding 1 van 2 Nintendo 3DS XL Microphone Replacement: stap 10, afbeelding 2 van 2
    • Using the flat head side of the spudger carefully lift up the flap and remove the ribbon.
    • The attached microphone can now be removed.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Charlene Donlon
11.225 Reputatie
8 handleidingen geschreven
Cal Poly, Team 9-13, Regan Spring 2014 Lid van Cal Poly, Team 9-13, Regan Spring 2014
CPSU-REGAN-S14S9G13
5 Leden
64 handleidingen geschreven
2Gids Commentaar
Hello! Do these instructions apply to the New 3DS XL as well? I followed steps from 1-8, but when I get to step 9, the layout is different and I can’t find the mic. Any help would be greatly appreciated!
Melissa Cardenas - Antwoord Deel
please learn to repair the mic of new 3ds xl
andrew.hws - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 169
Altijd: 15,800
