Inleiding
This guide will demonstrate how to replace any of the push button switches on the circuit board. Each button has four solder pads to desolder, and when replaced, must be in the correct orientation in order for your device to work.
Wat je nodig hebt
Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
Remove these four screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
Using a pair of scissors or wire cutters, cut the zip tie holding these wires.
This will give the circuit board more range of motion.
After the wires have cooled enough to touch, carefully slide the circuit board free of the wires.
NOTE: keep track of which pad each wire was soldered to. This is important for your blender to function.
After removing the circuit board from your device, locate which button you wish to replace.
On the opposite side of the circuit board from the button, there are four solder pads with the designation "SW" followed by a number.
To reassemble your device, follow these instructions in reverse order, except soldering when you desoldered previously.
