Ga door naar hoofdinhoud
Ninja Mega Kitchen System BL770 Button Replacement
Wat je nodig hebt
  1. Ninja Mega Kitchen System BL770 Button Replacement, Circuit Base: stap 1, afbeelding 1 van 2 Ninja Mega Kitchen System BL770 Button Replacement, Circuit Base: stap 1, afbeelding 2 van 2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Button Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Button Replacement: stap 3, afbeelding 1 van 3 Ninja Mega Kitchen System BL770 Button Replacement: stap 3, afbeelding 2 van 3 Ninja Mega Kitchen System BL770 Button Replacement: stap 3, afbeelding 3 van 3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Button Replacement: stap 4, afbeelding 1 van 1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Button Replacement, Button: stap 5, afbeelding 1 van 2 Ninja Mega Kitchen System BL770 Button Replacement, Button: stap 5, afbeelding 2 van 2
    • Locate which button you wish to replace.
    • On the back of the circuit board from the button, there are four solder pads with the designation "SW" followed by a number.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tommee Walker
823 Reputatie
6 handleidingen geschreven
4 opmerkingen
Hi! I changed the “power button” and when I plugged it back, it went on without the press of the button, and it didn’t work. Think I may have made a lousy soldering job… :/
Luis - Antwoord
Got a dead BL780. Pretty sure it’s the power switch as it’s been harder and harder to push to turn on. Going to attempt to replace on the board. I’m guessing that it’s a tactile momentary switch and that the board controls the power activation instead of the tactile switch being a push on/push off. Any insight would be appreciated.
Mark - Antwoord
Where can I purchase the power button?
Mark
Cenek Picka - Antwoord
Where can buy switch? What part number is the switch?
Mountain Buoy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 36
Altijd: 2,139
