Ga door naar hoofdinhoud
Ninja Master Prep QB900B button replacement
Wat je nodig hebt
    1. Ninja Master Prep QB900B button replacement, The Ninja Master Prep QB900B: stap 1, afbeelding 1 van 1
      • Place the blender to the side.
      Vraag FixBot
      Voeg opmerking toe
    2. Ninja Master Prep QB900B button replacement: stap 2, afbeelding 1 van 2 Ninja Master Prep QB900B button replacement: stap 2, afbeelding 2 van 2
      • Remove the two highlighted screws with a Phillips #2 Screw Driver
      • Gently pull off the top.
      Vraag FixBot
      Voeg opmerking toe
    1. Ninja Master Prep QB900B button replacement, Button: stap 3, afbeelding 1 van 1
      • Remove the highlighted screws.
      Vraag FixBot
      Voeg opmerking toe
    2. Ninja Master Prep QB900B button replacement: stap 4, afbeelding 1 van 1
      • Pull out the highlighted spring.
      • Now wash the button with soap and water, and follow the guide backwards to reassemble.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kamal Taha
679 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-3, Sullivan Fall 2015 Lid van USF Tampa, Team 1-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G3
3 Leden
17 handleidingen geschreven
2Gids Commentaar
mine has different screws and they won’t come out easily. looks like it might have a star head. thought it was hex and now the screws are stripped :(
Stephen Filippone - Antwoord Deel
turns out it was a security torx. how annoying.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 2,383
