Ga door naar hoofdinhoud
Nikon D90 Rear Display Buttons Replacement
Wat je nodig hebt
    1. Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: stap 1, afbeelding 1 van 2 Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: stap 1, afbeelding 2 van 2
      • Locate the screws on both sides of the camera.
      • Remove the four 6.3 mm Phillips screws using a PH00 screwdriver.
      • Be careful not to strip the screws.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: stap 2, afbeelding 1 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: stap 2, afbeelding 2 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: stap 2, afbeelding 3 van 3
      • Use a plastic opening tool to separate the rear case from the camera.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: stap 3, afbeelding 1 van 2 Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • After, remove the two orange ribbon connectors attached to the interior of the camera with tweezers.
      • Make sure to remove the ribbon cables carefully from the connectors to avoid damaging the camera.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: stap 4, afbeelding 1 van 2 Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: stap 4, afbeelding 2 van 2
      • Remove the screws from the back assembly with a Phillips (PH00) head screwdriver.
      • Remove the ten 5.3 mm Phillips screws.
      • Remove the three 4.3 mm Phillips screws.
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: stap 5, afbeelding 1 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: stap 5, afbeelding 2 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: stap 5, afbeelding 3 van 3
      • Use a plastic opening tool to separate the LCD and metal plates from the casing.
      Vraag FixBot
      Voeg opmerking toe
    6. Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: stap 6, afbeelding 1 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: stap 6, afbeelding 2 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: stap 6, afbeelding 3 van 3
      • Use a plastic opening tool to separate the buttons from the casing.
      • Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
jonothon cawley
354 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Lid van UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Leden
54 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 48
Altijd: 3,302
