Ga door naar hoofdinhoud
Nikon D90 Rear Case Replacement
Wat je nodig hebt
  1. Nikon D90 Rear Case Replacement, Rear Case: stap 1, afbeelding 1 van 2 Nikon D90 Rear Case Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Slide the eyepiece up and off the viewfinder.
  2. Nikon D90 Rear Case Replacement: stap 2, afbeelding 1 van 1
    • Using a PH000 screwdriver, remove the two 4.8mm Phillips screws from the back of the viewfinder.
    • Some screws may be JIS. Be wary of this if your PH000 does not feel like it is properly gripping the screws.
  3. Nikon D90 Rear Case Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 6.4mm Phillips screws on the right side of the camera, near the SD card slot.
  4. Nikon D90 Rear Case Replacement: stap 4, afbeelding 1 van 1
    • Remove the two 6.4mm Phillips screws on the left side of the camera, near the I/O ports.
  5. Nikon D90 Rear Case Replacement: stap 5, afbeelding 1 van 1
    • On the bottom of the camera,
    • remove the two 5.3mm Phillips screws
    • and the other two 6.3mm Phillips screws.
  6. Nikon D90 Rear Case Replacement: stap 6, afbeelding 1 van 3 Nikon D90 Rear Case Replacement: stap 6, afbeelding 2 van 3 Nikon D90 Rear Case Replacement: stap 6, afbeelding 3 van 3
    • Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step.
  7. Nikon D90 Rear Case Replacement: stap 7, afbeelding 1 van 2 Nikon D90 Rear Case Replacement: stap 7, afbeelding 2 van 2
    • Lift the rear case off of the back of the camera.
    • Don't pull the casing completely off yet, as the ribbon cables are still connected.
    • Be mindful of the two clips, making sure to keep the bottom panel far enough away to clear them.
  8. Nikon D90 Rear Case Replacement: stap 8, afbeelding 1 van 1
    • Set the rear casing off to the side so you can access the ZIF connectors.
    • The orientation shown in the picture seems to be the best position for the casing to sit comfortably without stressing the ribbon cable connections.
  9. Nikon D90 Rear Case Replacement: stap 9, afbeelding 1 van 3 Nikon D90 Rear Case Replacement: stap 9, afbeelding 2 van 3 Nikon D90 Rear Case Replacement: stap 9, afbeelding 3 van 3
    • Use a spudger to lift the black tab on the ZIF connector.
    • Disconnect the ribbon cables from their respective ZIF connectors on the logic board.
  10. Nikon D90 Rear Case Replacement: stap 10, afbeelding 1 van 1
    • Separate the rear casing from the camera.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Ryan Lutz
3.008 Reputatie
3 handleidingen geschreven
2 opmerkingen
good guidance,easy to follow,thanks
ramalingeswarao kaza - Antwoord
I want to replace my Nikon D90 DSLR bad LCD, this guide will save me from costly repairs.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 4,199
