Ga door naar hoofdinhoud
Nikon D80 Rear LCD Screen Replacement
Wat je nodig hebt
    1. Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: stap 1, afbeelding 1 van 3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: stap 1, afbeelding 2 van 3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: stap 1, afbeelding 3 van 3
      • Using a Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon D80 Rear LCD Screen Replacement: stap 2, afbeelding 1 van 3 Nikon D80 Rear LCD Screen Replacement: stap 2, afbeelding 2 van 3 Nikon D80 Rear LCD Screen Replacement: stap 2, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
      • Pull the orange connector cable away from the main body of the camera using the tweezers.
      • Remove the back cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon D80 Rear LCD Screen Replacement: stap 3, afbeelding 1 van 2 Nikon D80 Rear LCD Screen Replacement: stap 3, afbeelding 2 van 2
      • Using a Philips #00 screwdriver, remove the three 4.3 mm screws by rotating screwdriver to the left.
      • Use the Phillips #00 screwdriver to remove the two 3.4 mm screws.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon D80 Rear LCD Screen Replacement: stap 4, afbeelding 1 van 2 Nikon D80 Rear LCD Screen Replacement: stap 4, afbeelding 2 van 2
      • Using blunt tweezers, gently flip the small locking flap of the zero force insertion connector up for both connectors.
      • Use blunt tweezers to pull the left ribbon connector out of the zero insertion force connector.
      • Using the same tweezers, pull the right ribbon connector out of the zero insertion force connector.
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon D80 Rear LCD Screen Replacement: stap 5, afbeelding 1 van 2 Nikon D80 Rear LCD Screen Replacement: stap 5, afbeelding 2 van 2
      • Slide out the LCD screen by pulling towards the right.
      • Remove the LCD screen.
      • The buttons beside the screen fall out easily. Remember where they were and put them back when finished with the screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sara Martin
610 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G1, Leahy Fall 2017 Lid van USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 48
Altijd: 4,113
