Ga door naar hoofdinhoud
Nikon D80 Main Board Replacement
Wat je nodig hebt
  1. Nikon D80 Main Board Replacement, Main Board: stap 1, afbeelding 1 van 2 Nikon D80 Main Board Replacement, Main Board: stap 1, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Nikon D80 Main Board Replacement: stap 2, afbeelding 1 van 3 Nikon D80 Main Board Replacement: stap 2, afbeelding 2 van 3 Nikon D80 Main Board Replacement: stap 2, afbeelding 3 van 3
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Main Board Replacement: stap 3, afbeelding 1 van 3 Nikon D80 Main Board Replacement: stap 3, afbeelding 2 van 3 Nikon D80 Main Board Replacement: stap 3, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Nikon D80 Main Board Replacement: stap 4, afbeelding 1 van 2 Nikon D80 Main Board Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  5. Nikon D80 Main Board Replacement: stap 5, afbeelding 1 van 1
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  6. Nikon D80 Main Board Replacement: stap 6, afbeelding 1 van 3 Nikon D80 Main Board Replacement: stap 6, afbeelding 2 van 3 Nikon D80 Main Board Replacement: stap 6, afbeelding 3 van 3
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
    My D80 is displaying ERR no picture is saved when I click on the button, I can hear the shutter but no picture is saved. Firm ware is up to date. I was told maybe the ACU plastic screws are broken, where do you recommend buying parts? Your instructions are clear for removing the board. Thanks for that.
    Jose - Antwoord
Conclusie
Sara Martin
577 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G1, Leahy Fall 2017 Lid van USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Leden
5 handleidingen geschreven
Één opmerking
Is there a Nikon repair forum that might provide more detailed information?
this is the clearest instructions so far but I’m sure there are diagnostic codes for more precise troubleshooting
Mermaid - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 38
Altijd: 2,212
