Ga door naar hoofdinhoud
Nikon D610 Flash Capacitor Replacement
Wat je nodig hebt
  1. Nikon D610 Flash Capacitor Replacement, Battery: stap 1, afbeelding 1 van 1
    • First, power off the device.
  2. Nikon D610 Flash Capacitor Replacement: stap 2, afbeelding 1 van 3 Nikon D610 Flash Capacitor Replacement: stap 2, afbeelding 2 van 3 Nikon D610 Flash Capacitor Replacement: stap 2, afbeelding 3 van 3
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  3. Nikon D610 Flash Capacitor Replacement: stap 3, afbeelding 1 van 2 Nikon D610 Flash Capacitor Replacement: stap 3, afbeelding 2 van 2
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
  4. Nikon D610 Flash Capacitor Replacement, Outer Case: stap 4, afbeelding 1 van 1
    • After removal of the battery. Pull the battery compartment door away from the lens.
    • There are eleven Philips head screws that hold the bottom cover on, including a few inside the battery compartment.
    • Remove all the screws and the bottom face should pop off easily.
  5. Nikon D610 Flash Capacitor Replacement: stap 5, afbeelding 1 van 3 Nikon D610 Flash Capacitor Replacement: stap 5, afbeelding 2 van 3 Nikon D610 Flash Capacitor Replacement: stap 5, afbeelding 3 van 3
    • Then next step is removing the seven Philips #00 screws that hold the rear face plate on.
    • There are screws hidden in three separate spots.
    • One is under the rubber doors on the left side of the camera. the next one at the eye hole.
    • The final one involves taking off the small dial that is about half an inch to the right of the eye hole.
    • Removing this dial involves putting a spungder tool behind it and applying a gradual amount of pressure.
  6. Nikon D610 Flash Capacitor Replacement: stap 6, afbeelding 1 van 2 Nikon D610 Flash Capacitor Replacement: stap 6, afbeelding 2 van 2
    • The rear face plate will include the LCD display it separates from the body of the camera with a small tug.
    • Do not pull to hard otherwise you risk breaking the ribbon wire that connects the controls and the screen.
    • Once there is enough space it will be possible to gently pull the ribbon cable out of their ports.
  7. Nikon D610 Flash Capacitor Replacement: stap 7, afbeelding 1 van 2 Nikon D610 Flash Capacitor Replacement: stap 7, afbeelding 2 van 2
    • The next piece to come off is the front plate and the red grip.
    • The front plate is held on by 2 Philips #00 screws on the front and two more beneath the flash bulb.
    • Remove the two Phillips #00 screws holding on the grip and it slides off easily.
    • After removing the screws the face plate comes off by pulling it straight off to avoid damage.
  8. Nikon D610 Flash Capacitor Replacement: stap 8, afbeelding 1 van 2 Nikon D610 Flash Capacitor Replacement: stap 8, afbeelding 2 van 2
    • It is now possible to remove the last three Philips #00 screws that are hidden under the memory card slot door.
    • The screws come out and the cover comes straight off.
    • The last cover plate is the top. The top is held on by two screws located just beneath the rim of the cover.
    • The top should be pulled off very slowly. There are several electronic components that connect between the body and the top.
    • There are three wires that need to be disconnected.
  9. Nikon D610 Flash Capacitor Replacement, Flash Capacitor: stap 9, afbeelding 1 van 2 Nikon D610 Flash Capacitor Replacement, Flash Capacitor: stap 9, afbeelding 2 van 2
    • The flash capacitor will be to the right of the lens on the front of the camera.
    • There is only one connection that the flash capacitor makes but this was detached earlier.
    • The pictures shown for the flash capacitor removal is from a complete tear down.
  10. Nikon D610 Flash Capacitor Replacement: stap 10, afbeelding 1 van 1
    • If your flash capacitor looks damaged you can create a discharge tool with this guide. Maak zelf een tool om een condensator te ontladen
    • Then use the plastic opening tool to pry from underneath the capacitor from top to bottom in order to remove it.
    • Please note that there is glue holding the capacitor to the frame so it will need some coaxing to get it off.
Conclusie
Daniel Eagan
606 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-4, Lacy Spring 2016 Lid van USF Tampa, Team 4-4, Lacy Spring 2016
USFT-LACY-S16S4G4
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 1,221
