Ga door naar hoofdinhoud
Nikon D3000 Motherboard Replacement
Wat je nodig hebt
    1. Nikon D3000 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Nikon D3000 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
      • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right of the camera bottom.
      • Remove three 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom
      • Lift the battery cover and remove two 3 mm x 5 mm Phillips head screws.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon D3000 Motherboard Replacement: stap 2, afbeelding 1 van 3 Nikon D3000 Motherboard Replacement: stap 2, afbeelding 2 van 3 Nikon D3000 Motherboard Replacement: stap 2, afbeelding 3 van 3
      • Remove the two 3 mm x 5.5 mm Phillips head screws from the either side of the viewfinder.
      • Remove four 3 mm x 5.5 mm Phillips head screws from the sides of the camera.
      • Remove two 3 mm x 4 mm Phillips head screws from under the SD card door.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon D3000 Motherboard Replacement: stap 3, afbeelding 1 van 2 Nikon D3000 Motherboard Replacement: stap 3, afbeelding 2 van 2
      • Use the following process for removing all ribbon connectors.
      • Lift the back of the camera and, using the blue prying tool, lift the tab from the LCD ribbon connector.
      • Slide the ribbon connector away from the bottom of the camera and remove the back cover containing the LCD to expose the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon D3000 Motherboard Replacement: stap 4, afbeelding 1 van 2 Nikon D3000 Motherboard Replacement: stap 4, afbeelding 2 van 2
      • Soldering irons are hot; take all necessary precautions to not burn yourself or equipment.
      • Be sure to label each gray wire to be removed from the motherboard as they are the same color and can be mixed up during reassembly.
      • Lift the tab on the ribbon connector and pull away the ribbon to expose a 4 mm x 4 mm Phillips head screw.
      • De-solder the red (upper), two grey (lower), red (lower), and blue (lower) wires from the motherboard.
      • Remove five 4 mm x 4 mm Phillips head screws holding the motherboard to the camera frame.
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon D3000 Motherboard Replacement: stap 5, afbeelding 1 van 2 Nikon D3000 Motherboard Replacement: stap 5, afbeelding 2 van 2
      • Lift the tabs and pull away the ribbon connectors shown .
      • Lift the motherboard and disconnect the grey connector from the bottom.
      • Disconnect and remove the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Randall Heath
899 Reputatie
3 handleidingen geschreven
USF Tampa, Team 14-7, Meier Fall 2015 Lid van USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 43
Altijd: 4,917
