Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
Push the door open, and remove the existing battery with your fingers, per images 2-3.
Press the button located on the top-right side of the camera's body to open the flash compartment.
Position camera as seen in the image here. This will make using the tools much easier.
Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws from inside the flash compartment.
Place the Plastic Opening Tool along the crack on the side of the flash compartment cover.
Use this to pry open and detach the cover.
Using a Phillips #000 Precision Screwdriver, remove the 4.0 mm screw from the plastic cover.
Once the screw is removed, detach the plastic cover.
Carefully remove the flash bulb holder with your fingers. (Use image as a reference.)
The flash bulb holder is the black, cylinder cartridge.
Using the end of the Plastic Opening Tool, pry the metal bulb frame out of the socket. (See image for reference.)
Once metal bulb frame is removed from the holder, remove the plastic stoppers on both sides of the metal flash bulb tray.
Use your fingers, both plastic stoppers should pop off with ease.
Using a Soldering Iron, desolder each of the wires connected to the light bulb.
Give wires a few minutes to cool before reassembling the camera to avoid damage to any device components.
