Ga door naar hoofdinhoud
Nikon Coolpix L820 Settings Buttons Replacement
Wat je nodig hebt
    1. Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: stap 1, afbeelding 1 van 3 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: stap 1, afbeelding 2 van 3 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: stap 1, afbeelding 3 van 3
      • Remove the battery before beginning.
      • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are 10 screws around the casing. 3 are located on the left side of the camera, 6 are located on the bottom near the product label, and 1 is located on the right side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon Coolpix L820 Settings Buttons Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix L820 Settings Buttons Replacement: stap 2, afbeelding 2 van 2
      • Next, remove the screw held on top of the camera above the Nikon logo.
      • Moving to the bottom of the camera, open the empty battery slot, and locate the 4 screws in the compartment. Begin removing the 4 screws located within.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon Coolpix L820 Settings Buttons Replacement: stap 3, afbeelding 1 van 3 Nikon Coolpix L820 Settings Buttons Replacement: stap 3, afbeelding 2 van 3 Nikon Coolpix L820 Settings Buttons Replacement: stap 3, afbeelding 3 van 3
      • Using the spudger, begin prying the case from the device, carefully separating the rear housing from the camera assembly. Once the rear housing is separated, the camera's physical buttons will be accessible for replacement.
      • Be sure to only apply pressure to the casing panels, not internal electronics. Doing so can damage the internal components of the camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Marc
430 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-4, Miles Spring 2015 Lid van UMass Dartmouth, Team 1-4, Miles Spring 2015
UMASSD-MILES-S15S1G4
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 1,744
