Inleiding
If you encounter issues with your camera motherboard, follow this step by step guide to aid you on replacing it.
Wat je nodig hebt
There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
Two 1.5x2.5mm screws on the right side.
Two 1.5x2.5mm screws on the underside.
Two 1.5x2.5mm screw on the left side.
Insert the tips of your fingers into the space between the screen and back-plate.
Gently lift the screen up and out of the frame.
Remove the screws from the silver back-plate with a PH000 screw head.
Two 1.5x2.5mm screws on the left side.
One 1.5x2.5mm screw on the right side.
Één andere persoon heeft deze handleiding voltooid.
