Ga door naar hoofdinhoud
Nikon Coolpix L18 Lens Replacement
Wat je nodig hebt
    1. Nikon Coolpix L18 Lens Replacement, Back Cover: stap 1, afbeelding 1 van 1
      • Remove the memory stick from the camera.
      • Remove the batteries from the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon Coolpix L18 Lens Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix L18 Lens Replacement: stap 2, afbeelding 2 van 2
      • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
      • There is one screw hidden under the AV cover that also needs to be removed.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon Coolpix L18 Lens Replacement: stap 3, afbeelding 1 van 1
      • Pry the back cover from the left side of the camera. Remove the cover gently.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon Coolpix L18 Lens Replacement, LCD Screen: stap 4, afbeelding 1 van 1
      • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
      • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon Coolpix L18 Lens Replacement: stap 5, afbeelding 1 van 1
      • Remove the tape on the right side of the LCD screen.
      • Gently lift the LCD screen from its base.
      • Don't tug on the screen because it is still connected to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon Coolpix L18 Lens Replacement: stap 6, afbeelding 1 van 1
      • Lift the black latch connecting the LCD ribbon to the motherboard.
      • Gently pull the LCD ribbon out.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon Coolpix L18 Lens Replacement, Front Cover: stap 7, afbeelding 1 van 1
      • Pry back the front cover of the camera starting from the right side.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon Coolpix L18 Lens Replacement, Lens: stap 8, afbeelding 1 van 2 Nikon Coolpix L18 Lens Replacement, Lens: stap 8, afbeelding 2 van 2
      • Remove the 6 Phillips #00 screws anchoring the LCD base to the motherboard.
      • Remove the LCD base plate.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon Coolpix L18 Lens Replacement: stap 9, afbeelding 1 van 1
      • Gently pull the lens ribbon out.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon Coolpix L18 Lens Replacement: stap 10, afbeelding 1 van 1
      • Desolder the connection of the motherboard to the lens ribbon using a soldering iron and desoldering wick.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon Coolpix L18 Lens Replacement: stap 11, afbeelding 1 van 1
      • Lift up the black and copper covering on the left side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon Coolpix L18 Lens Replacement: stap 12, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Pull the wiring at the top right of the camera away from the lens with tweezers.
      Vraag FixBot
      Voeg opmerking toe
    6. Nikon Coolpix L18 Lens Replacement: stap 13, afbeelding 1 van 1
      • Remove the cross-hair shaped wire cap to the left of the lens.
      Vraag FixBot
      Voeg opmerking toe
    7. Nikon Coolpix L18 Lens Replacement: stap 14, afbeelding 1 van 2 Nikon Coolpix L18 Lens Replacement: stap 14, afbeelding 2 van 2
      • Remove the 3 screws holding the lens to the camera frame.
      • Two 3.8mm black Phillips #00 screws on the sides of the lens.
      • One 4.6mm silver Phillips #00 screw on the bottom of the lens.
      Vraag FixBot
      Voeg opmerking toe
    8. Nikon Coolpix L18 Lens Replacement: stap 15, afbeelding 1 van 1
      • There is a screw behind flash tube holding lens. Remove it, then gently pull the lens out. Be sure that the lens's ribbon clears the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Andrea Govea
373 Reputatie
2 handleidingen geschreven
Cal Poly, Team 9-23, Regan Fall 2010 Lid van Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 Leden
10 handleidingen geschreven
3Gids Commentaar
Be careful. I got painful shock from the flash capacitor even though the camera had been turned off and the batteries removed. It is the red and black wires and green tube on the left side.
Discharge it through a resistor. Trying to short it with a screwdriver made ahuge spark and left a mark on the screwdriver.
sdalimon - Antwoord Deel
Aconteceu-me o mesmo, agora não a consigo ligar.
O meu caro Sdalimon tem alguma sugestão?
Cumprimentos.
Alberto Lopes - Antwoord Deel
.....okay but how do I fix it???
John V - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 98
Altijd: 18,782
