Inleiding
Use this guide to replace the LCD.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Clearly visible damage to the LCD. It did not even light up.
Remove the screw from the right side.
Remove the visible screw from the left side.
Open the USB A/C cover, there is one more screw that needs to be removed. That is why it is important to always remove all covers...
Remove the three screws from the bottom.
Start splitting the case from the battery compartment. I used an opening tool, but fingernails will be sufficient as well.
Één andere persoon heeft deze handleiding voltooid.
