Ga door naar hoofdinhoud
Nikon Coolpix 7900 LCD Screen Replacement
Wat je nodig hebt
    1. Nikon Coolpix 7900 LCD Screen Replacement, Back Cover: stap 1, afbeelding 1 van 1
      • Remove the four 3.0mm screws on the bottom of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon Coolpix 7900 LCD Screen Replacement: stap 2, afbeelding 1 van 1
      • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon Coolpix 7900 LCD Screen Replacement: stap 3, afbeelding 1 van 1
      • Remove the two 3.0mm screws on the right side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon Coolpix 7900 LCD Screen Replacement: stap 4, afbeelding 1 van 1
      • Carefully open the back cover. Take care as there are connectors still attached.
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon Coolpix 7900 LCD Screen Replacement: stap 5, afbeelding 1 van 1
      • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
      Vraag FixBot
      Voeg opmerking toe
    6. Nikon Coolpix 7900 LCD Screen Replacement: stap 6, afbeelding 1 van 1
      • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
      • The back cover will be disconnected from the camera
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon Coolpix 7900 LCD Screen Replacement, LCD Screen: stap 7, afbeelding 1 van 1
      • First remove the three 2.5mm screws securing the LCD screen to the substrate. Make sure not to keep hold of the little metal connector by the top left screw!
      • Carefully flip the screen down to reveal the back of the screen
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon Coolpix 7900 LCD Screen Replacement: stap 8, afbeelding 1 van 1
      • Disconnect the ribbon cable and gray connector with red and black wires.
      • Depending on your spare part, you may now need to carefully pry the screen back cover off. It is held by a double sided sticky tape on the inside. Be gentle!
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kaky Payne
121 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-38, Regan Spring 2012 Lid van Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 36
Altijd: 2,101
