Ga door naar hoofdinhoud
Nikon Coolpix 5400 Battery Door Replacement
Wat je nodig hebt
  1. Nikon Coolpix 5400 Battery Door Replacement, Battery Door: stap 1, afbeelding 1 van 1
    • Remove one 3mm Phillips #0 screw from the top of the camera back cover.
  2. Nikon Coolpix 5400 Battery Door Replacement: stap 2, afbeelding 1 van 1
    • Remove three 3mm Phillips #0 screws from the side of the back cover.
  3. Nikon Coolpix 5400 Battery Door Replacement: stap 3, afbeelding 1 van 1
    • Lift memory card flap.
    • Remove one 3mm Phillips #0 screw from the side of the back case.
  4. Nikon Coolpix 5400 Battery Door Replacement: stap 4, afbeelding 1 van 1
    • Remove four 3mm Phillips #0 screws from the bottom of the back case.
  5. Nikon Coolpix 5400 Battery Door Replacement: stap 5, afbeelding 1 van 2 Nikon Coolpix 5400 Battery Door Replacement: stap 5, afbeelding 2 van 2
    • Use a plastic opening tool to gently pop the back case away from the body of the camera.
    • Pull the back case away from the camera very gently.
    • The connecting cables are very fragile and easily broken.
  6. Nikon Coolpix 5400 Battery Door Replacement: stap 6, afbeelding 1 van 1
    • Flip camera over so the bottom is facing up.
    • Push the sliding latch to open the battery door.
    • Push the press fit pin firmly with a flat-head screwdriver to release it from the hinge housing.
    • Push to the left, half the length of the pin.
  7. Nikon Coolpix 5400 Battery Door Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Grasp the press fit pin firmly with precision tweezers to pull it from the housing.
    • Do not to drop the pin into the camera body.
  8. Nikon Coolpix 5400 Battery Door Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery door by lifting it out of the camera body.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 306
