Ga door naar hoofdinhoud
Nikon Coolpix 5400 Battery Replacement
Wat je nodig hebt
  1. Nikon Coolpix 5400 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the camera so that the base is oriented facing up and the front of the camera is facing towards you.
  2. Nikon Coolpix 5400 Battery Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix 5400 Battery Replacement: stap 2, afbeelding 2 van 2
    • Push the battery compartment door latch, located on the right-hand side of the camera, away from you to release the catch.
    • Release the latch and pull your hand away. The spring inside the compartment will push both the battery up and the door open.
    • Push the battery door the rest of the way open to fully expose the battery.
  3. Nikon Coolpix 5400 Battery Replacement: stap 3, afbeelding 1 van 1
    • Grasp the battery with your thumb and forefinger and pull up and out of the camera housing.
Conclusie
2 opmerkingen
I want to buy charger
MdYasir# - Antwoord
I have a changer but it is not working.please help me to charge it
MdYasir# - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 485
