Ga door naar hoofdinhoud
Nikon COOLPIX S610c Lens Assembly Replacement
Wat je nodig hebt
    1. Nikon COOLPIX S610c Lens Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
      • On the bottom right of the camera, locate the battery flap switch.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon COOLPIX S610c Lens Assembly Replacement: stap 2, afbeelding 1 van 1
      • Move this switch to the right so the battery flap can flip open.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon COOLPIX S610c Lens Assembly Replacement: stap 3, afbeelding 1 van 1
      • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon COOLPIX S610c Lens Assembly Replacement, Rear Casing: stap 4, afbeelding 1 van 1
      • Remove the three 3x3mm screws attached to the rear casing.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon COOLPIX S610c Lens Assembly Replacement: stap 5, afbeelding 1 van 1
      • The panel can be identified by the wifi logo on its upper half on the camera's side.
      • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon COOLPIX S610c Lens Assembly Replacement: stap 6, afbeelding 1 van 1
      • Pry the panel off from the bottom using your fingernail.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon COOLPIX S610c Lens Assembly Replacement: stap 7, afbeelding 1 van 1
      • Remove the 3x2mm screw underneath the panel near the top of the camera.
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon COOLPIX S610c Lens Assembly Replacement: stap 8, afbeelding 1 van 2 Nikon COOLPIX S610c Lens Assembly Replacement: stap 8, afbeelding 2 van 2
      • Remove the 4x3mm on the opposite side near the selector wheel.
      • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
      Vraag FixBot
      Voeg opmerking toe
    6. Nikon COOLPIX S610c Lens Assembly Replacement: stap 9, afbeelding 1 van 2 Nikon COOLPIX S610c Lens Assembly Replacement: stap 9, afbeelding 2 van 2
      • Pry the back panel away from the body of the camera, using the space you just opened up.
      • Be careful not to damage the ribbon cable on the opposite end of the camera.
      • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
      Vraag FixBot
      Voeg opmerking toe
    7. Nikon COOLPIX S610c Lens Assembly Replacement: stap 10, afbeelding 1 van 2 Nikon COOLPIX S610c Lens Assembly Replacement: stap 10, afbeelding 2 van 2
      • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
      • The center connector is detached by flipping the black latch up and away from the center of the camera.
      • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon COOLPIX S610c Lens Assembly Replacement, Front Casing: stap 11, afbeelding 1 van 1
      • Remove the three 3x3mm screws that attach the front casing to the bottom.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon COOLPIX S610c Lens Assembly Replacement: stap 12, afbeelding 1 van 1
      • Remove the two 3x2 screws and two 3.5x2.5 screws attaching the rear panel to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon COOLPIX S610c Lens Assembly Replacement: stap 13, afbeelding 1 van 2 Nikon COOLPIX S610c Lens Assembly Replacement: stap 13, afbeelding 2 van 2
      • Lift the back panel off the motherboard.
      • Be careful not to damage the ribbon cable that attaches the mother board to the rear panel.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon COOLPIX S610c Lens Assembly Replacement: stap 14, afbeelding 1 van 2 Nikon COOLPIX S610c Lens Assembly Replacement: stap 14, afbeelding 2 van 2
      • Detach the ribbon cable from the motherboard by flipping up the latch on the ribbon connector.
      • Note that the white ribbon connector latch flips away from the ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon COOLPIX S610c Lens Assembly Replacement: stap 15, afbeelding 1 van 2 Nikon COOLPIX S610c Lens Assembly Replacement: stap 15, afbeelding 2 van 2
      • Remove the final 4x3mm screw at the top of the camera near the lens.
      Vraag FixBot
      Voeg opmerking toe
    6. Nikon COOLPIX S610c Lens Assembly Replacement: stap 16, afbeelding 1 van 2 Nikon COOLPIX S610c Lens Assembly Replacement: stap 16, afbeelding 2 van 2
      • Pry the front casing away from the body of the camera.
      • Be careful not to damage the wires that attach the front panel to the motherboard.
      • Short the leads on the capacitor near the flash to avoid a nasty shock when separating the casing from the body.
      Vraag FixBot
      Voeg opmerking toe
    7. Nikon COOLPIX S610c Lens Assembly Replacement: stap 17, afbeelding 1 van 1
      • Unscrew the three 3x2mm screws that attach the cables to the front casing.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon COOLPIX S610c Lens Assembly Replacement, Lens Assembly: stap 18, afbeelding 1 van 2 Nikon COOLPIX S610c Lens Assembly Replacement, Lens Assembly: stap 18, afbeelding 2 van 2
      • Pry up the ribbon connector that connects the ribbon cable to the lens assembly.
      • Take note that the ribbon connector pulls away from the ribbon.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kevin Backers
304 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-5, Regan Winter 2012 Lid van Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
5 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 1,270
