Ga door naar hoofdinhoud
Nikon COOLPIX S610c LCD Replacement
Wat je nodig hebt
    1. Nikon COOLPIX S610c LCD Replacement, Battery: stap 1, afbeelding 1 van 1
      • On the bottom right of the camera, locate the battery flap switch.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon COOLPIX S610c LCD Replacement: stap 2, afbeelding 1 van 1
      • Move this switch to the right so the battery flap can flip open.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon COOLPIX S610c LCD Replacement: stap 3, afbeelding 1 van 1
      • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon COOLPIX S610c LCD Replacement, Rear Casing: stap 4, afbeelding 1 van 1
      • Remove the three 3x3mm screws attached to the rear casing.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon COOLPIX S610c LCD Replacement: stap 5, afbeelding 1 van 1
      • The panel can be identified by the wifi logo on its upper half on the camera's side.
      • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon COOLPIX S610c LCD Replacement: stap 6, afbeelding 1 van 1
      • Pry the panel off from the bottom using your fingernail.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon COOLPIX S610c LCD Replacement: stap 7, afbeelding 1 van 1
      • Remove the 3x2mm screw underneath the panel near the top of the camera.
      Vraag FixBot
      Voeg opmerking toe
    5. Nikon COOLPIX S610c LCD Replacement: stap 8, afbeelding 1 van 2 Nikon COOLPIX S610c LCD Replacement: stap 8, afbeelding 2 van 2
      • Remove the 4x3mm on the opposite side near the selector wheel.
      • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
      Vraag FixBot
      Voeg opmerking toe
    6. Nikon COOLPIX S610c LCD Replacement: stap 9, afbeelding 1 van 2 Nikon COOLPIX S610c LCD Replacement: stap 9, afbeelding 2 van 2
      • Pry the back panel away from the body of the camera, using the space you just opened up.
      • Be careful not to damage the ribbon cable on the opposite end of the camera.
      • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
      Vraag FixBot
      Voeg opmerking toe
    7. Nikon COOLPIX S610c LCD Replacement: stap 10, afbeelding 1 van 2 Nikon COOLPIX S610c LCD Replacement: stap 10, afbeelding 2 van 2
      • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
      • The center connector is detached by flipping the black latch up and away from the center of the camera.
      • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Nikon COOLPIX S610c LCD Replacement, LCD: stap 11, afbeelding 1 van 2 Nikon COOLPIX S610c LCD Replacement, LCD: stap 11, afbeelding 2 van 2
      • Pry the display from the rear casing using a spudger.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kevin Backers
304 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-5, Regan Winter 2012 Lid van Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
5 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 1,035
