Reparatiehandleidingen
App
Je zakreparatiehulpje.
FixBot
De vriendelijke AI-reparatieassistent.
Repareerbaarheid
Demontages
Antwoordenforum
Vind je gemeenschap
Zoek teams, evenementen en collega-fixers.
Help mee
Help reparatiekennis gratis en toegankelijk te maken voor iedereen.
Right to Repair
Aanbevolen
Gereedschap
Onderdelen
iPhone Batterijen
Remove the screw located near the speaker port using a Phillips 00 screwdriver.
Turn camera upside down so that the battery compartment is facing you.
Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
Rotate the camera to the opposite side where the A/V outlet is located.
Unscrew and remove all four screws with a Phillips 00 screwdriver.
Turn the camera so that the Wi-Fi adapter is facing you.
Using a plastic opening tool, pry the front casing of the camera.
Continue this motion all around the front casing of the camera.
Gently pull apart the front casing from the rest of the camera.
Using the plastic opening tool pry the back casing of the camera.
Orange ribbon is fragile
Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
Pull apart the orange ribbon and front casing from the rest of the camera.
Use plastic opening tool to carefully pry the LCD Screen from the camera.
Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
De-solder the black and red wires from the mainboard.
Using a soldering iron can be dangerous! Refer to the iFiixit Soldering Iron Safety Information Page Use caution while attempting this repair.
met 5 andere bijdragers
31 Reputatie
3 handleidingen geschreven
Medailles: 9
+6 andere badges
CPSU-AMIDO-W12S3G28
4 Leden
45 handleidingen geschreven
Kies een formaat en kopieer de code hieronder om deze handleiding als een kleine widget op je website of forum in te sluiten.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 1,463
