Ga door naar hoofdinhoud
Nikon 1 J3 LCD Screen Replacement
Wat je nodig hebt
    1. Nikon 1 J3 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 2 Nikon 1 J3 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 2
      • Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
      • Remove the screws under the flaps covering the HDMI and mini USB ports.
      Vraag FixBot
      Voeg opmerking toe
    2. Nikon 1 J3 LCD Screen Replacement: stap 2, afbeelding 1 van 1
      • Carefully pry back the back plate.
      • The plastic of the back plate may crack.
      Vraag FixBot
      Voeg opmerking toe
    3. Nikon 1 J3 LCD Screen Replacement: stap 3, afbeelding 1 van 1
      • Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
      Vraag FixBot
      Voeg opmerking toe
    4. Nikon 1 J3 LCD Screen Replacement: stap 4, afbeelding 1 van 1
      • Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Austin Lackey
506 Reputatie
4 handleidingen geschreven
USF Tampa, Team S11-G4, Passmore Fall 2017 Lid van USF Tampa, Team S11-G4, Passmore Fall 2017
USFT-PASSMORE-F17S11G4
3 Leden
3Gids Commentaar
Hey, I’m having trouble removing the back plate on step 2. It seems to be stuck on the side opposite the HDMI and USB ports, any tips for removing it? Thanks!
johnjames460 - Antwoord Deel
Step 1 seems to mis removal of 2 screws. Check tutorial below:
https://www.lifepixel.com/tutorials/infr...
Marcel Rossewij - Antwoord Deel
I am about to replace the lcd screen on my J4 - is the method the same as for the J3? And do I need any adhesive?
Nicholas Glover - 2nd April 2023
Nicholas Glover - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 41
Altijd: 1,729
