Ga door naar hoofdinhoud
Nike SportWatch GPS LCD Screen Replacement
Wat je nodig hebt
    1. Nike SportWatch GPS LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
      • First, place the watch upside down so the back of the watch is exposed. Unscrew the six size #000 5 mm long screws located on the back panel using a size 000 Phillips head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Nike SportWatch GPS LCD Screen Replacement: stap 2, afbeelding 1 van 1
      • Carefully separate the watch by pulling the band away from the main board.
      Vraag FixBot
      Voeg opmerking toe
    3. Nike SportWatch GPS LCD Screen Replacement: stap 3, afbeelding 1 van 1
      • Then, unscrew the two main board size #000 2.5 mm long screws using a size 000 Phillips head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Nike SportWatch GPS LCD Screen Replacement: stap 4, afbeelding 1 van 1
      • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
      • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and is not removable.
      Vraag FixBot
      Voeg opmerking toe
    5. Nike SportWatch GPS LCD Screen Replacement: stap 5, afbeelding 1 van 1
      • Use the blue plastic removal tool once again to carefully remove the screen.
      Vraag FixBot
      Voeg opmerking toe
    6. Nike SportWatch GPS LCD Screen Replacement: stap 6, afbeelding 1 van 1
      • Pull the plastic piece that is highlighted in the picture out from the back of the screen.
      Vraag FixBot
      Voeg opmerking toe
    7. Nike SportWatch GPS LCD Screen Replacement: stap 7, afbeelding 1 van 1
      • For reassembly, make sure the highlighted area in the picture, goes over the black plastic piece that was removed in the previous step.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Zainab Hussein
222 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Leden
5 handleidingen geschreven
3Gids Commentaar
Hello, I found your article very interesting, I was just wondering do you know where I can buy a replacement screen?
Thank you
Joseph Kermani - Antwoord Deel
hello do you know where I can find a replacement screen ?
Thank you
SMOUN - Antwoord Deel
I googled the part number on the screen
http://www.mouser.com/search/ProductDeta...
Joshua Pantarotto - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 32
Altijd: 3,901
