Ga door naar hoofdinhoud
Nike SportWatch GPS Front Panel Replacement
Wat je nodig hebt
  1. Nike SportWatch GPS Front Panel Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Face the watch upside down so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws on the back using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Front Panel Replacement: stap 2, afbeelding 1 van 1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Front Panel Replacement: stap 3, afbeelding 1 van 1
    • Two size #000 2.5 mm long screws will appear at the top of the main board. Unscrew them using a size 000 Phillips head screwdriver.
  4. Nike SportWatch GPS Front Panel Replacement: stap 4, afbeelding 1 van 1
    • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and not removable.
  5. Nike SportWatch GPS Front Panel Replacement: stap 5, afbeelding 1 van 1
    • Use an iOpener that has been heated in the microwave for about a minute, or until warm. Place it on the front screen of the watch. Let it rest there for a minute.
    • If you are unfamiliar with this tool use the iOpener guide here
  6. Nike SportWatch GPS Front Panel Replacement: stap 6, afbeelding 1 van 1
    • Push the panel out from the back of the screen, using your fingers.
Conclusie
Ian Eichorn
678 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Leden
5 handleidingen geschreven
Één opmerking
Where I can find the replacement glass? regards
Erick Sobreiro - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 1,263
