Ga door naar hoofdinhoud
Nike SportWatch GPS Battery Replacement
Wat je nodig hebt
    1. Nike SportWatch GPS Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws using a size 000 Phillips head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Nike SportWatch GPS Battery Replacement: stap 2, afbeelding 1 van 1
      • Carefully separate the watch by pulling the band away from the main board.
      Vraag FixBot
      Voeg opmerking toe
    3. Nike SportWatch GPS Battery Replacement: stap 3, afbeelding 1 van 1
      • Pry the black plastic piece above the battery out using a nylon or metal spudger.
      • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
      Vraag FixBot
      Voeg opmerking toe
    4. Nike SportWatch GPS Battery Replacement: stap 4, afbeelding 1 van 1
      • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
      Vraag FixBot
      Voeg opmerking toe
    5. Nike SportWatch GPS Battery Replacement: stap 5, afbeelding 1 van 1
      • The battery should then easily come out of the watch.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Once reassembled, plug the watch back into a USB computer port to turn the watch back on and start the initial charge. Let charge to full capacity.
9 andere personen hebben deze handleiding voltooid.
Ian Eichorn
696 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Leden
40 handleidingen geschreven
8Gids Commentaar
Nice tutorial!
Do you know where I can buy the battery from?
Steeve H - Antwoord Deel
Where can i buy a replacement battery?
Ricardo Henriques - Antwoord Deel
Looks like you can buy them on ebay: http://www.ebay.com/itm/-/131819485344?
FixerUpper - Antwoord Deel
Thank you for this guide and the link to the replacement battery.
The battery I received had an extra circuit board and the contacts/metal bands were thinner and further apart thus making direct replacement difficult, there was no way to create proper connection with the spring contacts using the black plastic pc . I ended up removing the extra PCB and soldered the battery with short leads directly to the spring contacts and this worked well.
Unfortunately, it seems the battery wasn't the only issue with the watch.. last night it was fully charged however by this morning it was almost totally empty.
amveszter - Antwoord Deel
I bought mine from batteryspace.com. Great place for all battery types.
peezo83 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 46
Altijd: 18,142
