Ga door naar hoofdinhoud
Nike SportWatch GPS Back Panel Replacement
Wat je nodig hebt
    1. Nike SportWatch GPS Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
      • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six #000 size 5 mm long screws on the back using a size 000 Phillips head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Nike SportWatch GPS Back Panel Replacement: stap 2, afbeelding 1 van 1
      • Carefully separate the watch by pulling the band away from the main board.
      Vraag FixBot
      Voeg opmerking toe
    3. Nike SportWatch GPS Back Panel Replacement: stap 3, afbeelding 1 van 1
      • Pry the black plastic piece above the battery out using a nylon or metal spudger.
      • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
      Vraag FixBot
      Voeg opmerking toe
    4. Nike SportWatch GPS Back Panel Replacement: stap 4, afbeelding 1 van 1
      • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
      Vraag FixBot
      Voeg opmerking toe
    5. Nike SportWatch GPS Back Panel Replacement: stap 5, afbeelding 1 van 1
      • After taking the battery out, you will be left with just the band and the backpanel part of the watch.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Ian Eichorn
696 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Leden
5 handleidingen geschreven
3Gids Commentaar
Where can I find a new watch band?
rhalljr68 - Antwoord Deel
You can´t. Nike left us alone
Leonardo Cartier - Antwoord Deel
So, no way to repair the band then if there's no replacement parts? :(
roycy Tan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 38
Altijd: 2,934
