Ga door naar hoofdinhoud
Nexus Q LED Board Replacement
Wat je nodig hebt
    1. Nexus Q LED Board Replacement, Ball Bearing Ring: stap 1, afbeelding 1 van 1
      • Squeeze and pull the cap to remove it from the Nexus Q.
      Vraag FixBot
      Voeg opmerking toe
    2. Nexus Q LED Board Replacement: stap 2, afbeelding 1 van 1
      • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
      Vraag FixBot
      Voeg opmerking toe
    3. Nexus Q LED Board Replacement: stap 3, afbeelding 1 van 1
      • Undo the ZIF connector by prying it with a spudger.
      Vraag FixBot
      Voeg opmerking toe
    4. Nexus Q LED Board Replacement: stap 4, afbeelding 1 van 1
      • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
      • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
      Vraag FixBot
      Voeg opmerking toe
    5. Nexus Q LED Board Replacement: stap 5, afbeelding 1 van 1
      • View the bottom half of the Nexus Q.
      • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
      Vraag FixBot
      Voeg opmerking toe
    6. Nexus Q LED Board Replacement: stap 6, afbeelding 1 van 1
      • Remove the ball bearing ring.
      • When placing a new ring in its place, make sure to orient it right or the top will not close.
      Vraag FixBot
      Voeg opmerking toe
    1. Nexus Q LED Board Replacement, LED Board: stap 7, afbeelding 1 van 2 Nexus Q LED Board Replacement, LED Board: stap 7, afbeelding 2 van 2
      • Once you remove the ball bearing ring from the bottom half of the Nexus Q, you will be exposed to a diffuser (white ring) held in with three T6 Torx screws.
      • Use a #0 Philips head screwdriver to remove the three 0.8 mm screws holding the diffuser in place.
      Vraag FixBot
      Voeg opmerking toe
    2. Nexus Q LED Board Replacement: stap 8, afbeelding 1 van 2 Nexus Q LED Board Replacement: stap 8, afbeelding 2 van 2
      • With the diffuser out, we are exposed to the LED Board.
      • Use a spudger to lightly lift the LED board out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Taewan Kim
22 Reputatie
2 handleidingen geschreven
Cal Poly, Team 7-10, Maness Winter 2013 Lid van Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 Leden
45 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 31
Altijd: 868
