Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Nexus 7 2nd Generation Micro USB/Daughterboard Replacement
Wat je nodig hebt
  1. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement, Back Cover: stap 1, afbeelding 1 van 2 Nexus 7 2nd Generation Micro USB/Daughterboard Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Power down your device.
    • Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time. For some a finger nail may be best. The case comes up quite high to the glass.
    • Do not pry near the USB port at the base of the device as you may crack the rear panel.
  2. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 2, afbeelding 1 van 1
    • Work fingers around the seam between device and back cover. Use your plastic opening tool and fingers to separate each side until device and back cover are completely apart.
    • Be careful around the corners. The body of the device can be fragile.
  3. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Insert the plastic opening tool under the side edge of the battery connector, and gently pry upward to disconnect it.
  4. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 4, afbeelding 1 van 3 Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 4, afbeelding 2 van 3 Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 4, afbeelding 3 van 3
    • Use the flat end of a spudger or your fingernail to flip up the clear protective flap on the ribbon cable ZIF socket.
    • Using the flat end of a spudger or your fingernail, flip up the thin portion of the connector (the white part, opposite of the side where the cable inserts) to release the cable from its socket.
    • DO NOT PRY the socket on the side where the cable inserts, or you may break the entire socket off the motherboard.
    • Slide the cable out of the ZIF socket.
    • For more info on how to disconnect ZIF connectors, check out the Recognizing & Disconnecting Cable Connectors guide.
  5. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 5, afbeelding 1 van 1
    • Peel protective foil cover back top of mother board to expose orange ribbon connection.
    • The ribbon connections should now be fully visible, with the plastic tabs exposed.
  6. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 6, afbeelding 1 van 3 Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 6, afbeelding 2 van 3 Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 6, afbeelding 3 van 3
    • Using the tweezers, peel back the silver protective foil on top of the orange ribbon connector.
    • Using the plastic opening tool, pry upward under the orange ribbon connector. It will pop right out of place.
  7. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 7, afbeelding 1 van 2 Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 7, afbeelding 2 van 2
    • Now that the two main ribbons are disconnected, fold and hold them back with your fingers, or place the tweezers or a light object on the ribbons to keep them in place.
  8. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 8, afbeelding 1 van 1
    • Use the #0 Phillips Screwdriver to remove the four silver 3 mm Philips #0 screws from around the battery housing.
  9. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the battery from your device by applying pressure at the base of the battery and lifting it out.
  10. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement, Micro USB/Daughterboard: stap 10, afbeelding 1 van 2 Nexus 7 2nd Generation Micro USB/Daughterboard Replacement, Micro USB/Daughterboard: stap 10, afbeelding 2 van 2
    • Remove the gray seal covering the top center screw on the daughterboard.
    • Be aware that this action will void your warranty.
    • Be sure to store the seal in a place where it will not get dirty and can retain its stickiness.
  11. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 11, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, unscrew the 5 black 2 mm sized screws from around the edge of the daughterboard.
    • Use the same Phillips #0 screwdriver to remove the two silver 3 mm sized screws from either side of the micro USB.
  12. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 12, afbeelding 1 van 2 Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 12, afbeelding 2 van 2
    • Use the tweezers to unplug the speaker connector from the daughterboard by pulling sideways.
    • Be gentle in this step as this connector can be fragile. Do not pull upwards.
  13. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 13, afbeelding 1 van 1
    • Slowly peel off the cover adhered to the pin connector with the tweezers.
  14. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 14, afbeelding 1 van 2 Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 14, afbeelding 2 van 2
    • Use the flat end of a spudger or your fingernail to carefully flip up both retaining flaps one each of the ZIF sockets.
    • When disconnecting the ZIF sockets flip them outwards to the edge of the board/towards the cables respectively.
    • Be careful not to damage the pin connector. Pull parallel to the device, not up.
  15. Nexus 7 2nd Generation Micro USB/Daughterboard Replacement: stap 15, afbeelding 1 van 1
    • The daughterboard will now lift easily up and out of the device.
    • Use care during reassembly. This daughter board is a very sensitive part. It is easy to fry the digitizer part of this board if connections are made in the wrong order. Complete all other cable connections before connecting battery power.
Conclusie
46 andere personen hebben deze handleiding voltooid.
Simon Krauter
1.752 Reputatie
1 Handleiding geschreven
Cal Poly, Team 20-16, Maness Winter 2015 Lid van Cal Poly, Team 20-16, Maness Winter 2015
CPSU-MANESS-W15S20G16
4 Leden
24 handleidingen geschreven
11 opmerkingen
Hi,
I need to replace USB connector on my Nexus7-2013 wifi, buit I had see on ASUS web site, if I change this spart, i need to recalibrate the unit .http://www.asusparts.eu/fr/Asus-90NK0080...
Is it true ?
Thx for your answer
Vincent PONS - Antwoord
According to these repair stories, it worked fine without any mentions of a need to calibrate: Nexus 7 (2nd Gen Wi-Fi) LCD Board
beanthedemon -
Great guide, easy to follow, the only input I would add is that stating which direction the zif connectors open would be helpful for newbies like me :)
lyleinnes - Antwoord
Hello i have a problem with a spudger in the daughter board, i crashed one of them will replacing the screen, i need to know how to fix it or the best place to buy a used daughter board
Hady Allam - Antwoord
My nexus 7 2013 wifi is charging fine with the existing board, but when I connect it to PC, it doesn't open the USB connection. Now, do I get the replacement or is this is a software bug?
manohar.m - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 73
Altijd: 36,091
