Ga door naar hoofdinhoud
Nexus 4 Plastic Midframe Replacement
Wat je nodig hebt
  1. Nexus 4 Plastic Midframe Replacement, Back Cover: stap 1, afbeelding 1 van 2 Nexus 4 Plastic Midframe Replacement, Back Cover: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    SIM Card Eject Tool
    $2.99
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
    Vraag FixBot
    Voeg opmerking toe
  2. Nexus 4 Plastic Midframe Replacement: stap 2, afbeelding 1 van 1
    T5 Torx Screwdriver
    $5.49
    Vraag FixBot
    Voeg opmerking toe
  3. Nexus 4 Plastic Midframe Replacement: stap 3, afbeelding 1 van 3 Nexus 4 Plastic Midframe Replacement: stap 3, afbeelding 2 van 3 Nexus 4 Plastic Midframe Replacement: stap 3, afbeelding 3 van 3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. Nexus 4 Plastic Midframe Replacement, Battery: stap 4, afbeelding 1 van 2 Nexus 4 Plastic Midframe Replacement, Battery: stap 4, afbeelding 2 van 2
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  5. Nexus 4 Plastic Midframe Replacement, Battery removal: stap 5, afbeelding 1 van 2 Nexus 4 Plastic Midframe Replacement, Battery removal: stap 5, afbeelding 2 van 2
    Plastic Cards
    $2.99
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
    Vraag FixBot
    Voeg opmerking toe
  6. Nexus 4 Plastic Midframe Replacement, Plastic Midframe: stap 6, afbeelding 1 van 3 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: stap 6, afbeelding 2 van 3 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: stap 6, afbeelding 3 van 3
    • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
    • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Kaitlyn Jones
4.964 Reputatie
8 handleidingen geschreven
Cal Poly, Team 3-32, Amido Winter 2013 Lid van Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 49
Altijd: 11,597
