Inleiding
Earphone jacks sometimes need to be replaced. This guide will take you through the steps to replace the earphone jack. You will begin by removing the battery, then the motherboard. and finish by de-soldering. The most difficult part will be de-soldering, so please review the link to Soldering Skills before de-soldering the earphone jack from the motherboard. The entire process ranges from moderately to very difficult and will take you approximately 50 minutes to complete.
Wat je nodig hebt
•With the tip of the thin metal spudger in place, use a prying motion to work the spudger down the side to the corner of the device.
Locate and remove the yellow cellophane tape from the display assembly ribbon cable ZIF connector.
