Ga door naar hoofdinhoud
NexiGo NS32 Trigger Assembly Replacement
Wat je nodig hebt
  1. NexiGo NS32 Trigger Assembly Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Orient the controller so that it is face down.
    Vraag FixBot
    Voeg opmerking toe
  2. NexiGo NS32 Trigger Assembly Replacement: stap 2, afbeelding 1 van 2 NexiGo NS32 Trigger Assembly Replacement: stap 2, afbeelding 2 van 2
    • Remove the eight 9 mm Phillips screws that secure the rear case.
    Vraag FixBot
    Voeg opmerking toe
  3. NexiGo NS32 Trigger Assembly Replacement: stap 3, afbeelding 1 van 1
    • Lift the rear case up and off.
    • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
    Vraag FixBot
    Voeg opmerking toe
  4. NexiGo NS32 Trigger Assembly Replacement, Battery: stap 4, afbeelding 1 van 2 NexiGo NS32 Trigger Assembly Replacement, Battery: stap 4, afbeelding 2 van 2
    • Grip the white battery connector and pull it directly out of its motherboard socket.
    • This may require some force, as the connectors are secured with a bit of adhesive. If you're having trouble with disconnection, apply some high-concentration isopropyl alcohol to the adhesive to loosen it.
    • Do not pull on the wires.
    Vraag FixBot
    Voeg opmerking toe
  5. NexiGo NS32 Trigger Assembly Replacement: stap 5, afbeelding 1 van 3 NexiGo NS32 Trigger Assembly Replacement: stap 5, afbeelding 2 van 3 NexiGo NS32 Trigger Assembly Replacement: stap 5, afbeelding 3 van 3
    • Lift the battery up and out.
    • Take care not to bend or puncture the battery as you remove it.
    Vraag FixBot
    Voeg opmerking toe
  6. NexiGo NS32 Trigger Assembly Replacement, Joystick PCB: stap 6, afbeelding 1 van 2 NexiGo NS32 Trigger Assembly Replacement, Joystick PCB: stap 6, afbeelding 2 van 2
    • Remove the three 9 mm Phillips screws that secure the joystick PCB.
    Vraag FixBot
    Voeg opmerking toe
  7. NexiGo NS32 Trigger Assembly Replacement: stap 7, afbeelding 1 van 2 NexiGo NS32 Trigger Assembly Replacement: stap 7, afbeelding 2 van 2
    • Flip up the black ZIF connector locking flap on the left side of the joystick PCB.
    • Pull the ribbon cable directly out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  8. NexiGo NS32 Trigger Assembly Replacement: stap 8, afbeelding 1 van 3 NexiGo NS32 Trigger Assembly Replacement: stap 8, afbeelding 2 van 3 NexiGo NS32 Trigger Assembly Replacement: stap 8, afbeelding 3 van 3
    • Lift out the joystick PCB.
    Vraag FixBot
    Voeg opmerking toe
  9. NexiGo NS32 Trigger Assembly Replacement, Trigger Assembly: stap 9, afbeelding 1 van 1
    • Flip up the black ZIF locking flap that secures the trigger assembly ribbon cable.
    • Disconnect the ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  10. NexiGo NS32 Trigger Assembly Replacement: stap 10, afbeelding 1 van 2 NexiGo NS32 Trigger Assembly Replacement: stap 10, afbeelding 2 van 2
    • Gently lift out the trigger assembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Gage_Atx
85 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 33
Altijd: 324
