Ga door naar hoofdinhoud
NexiGo NS32 Battery Replacement
Wat je nodig hebt
  1. NexiGo NS32 Battery Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Orient the controller so that it is face down.
    Vraag FixBot
    Voeg opmerking toe
  2. NexiGo NS32 Battery Replacement: stap 2, afbeelding 1 van 2 NexiGo NS32 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the eight 9 mm Phillips screws that secure the rear case.
    Vraag FixBot
    Voeg opmerking toe
  3. NexiGo NS32 Battery Replacement: stap 3, afbeelding 1 van 1
    • Lift the rear case up and off.
    • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
    Vraag FixBot
    Voeg opmerking toe
  4. NexiGo NS32 Battery Replacement, Battery: stap 4, afbeelding 1 van 2 NexiGo NS32 Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Grip the white battery connector and pull it directly out of its motherboard socket.
    • This may require some force, as the connectors are secured with a bit of adhesive. If you're having trouble with disconnection, apply some high-concentration isopropyl alcohol to the adhesive to loosen it.
    • Do not pull on the wires.
    Vraag FixBot
    Voeg opmerking toe
  5. NexiGo NS32 Battery Replacement: stap 5, afbeelding 1 van 3 NexiGo NS32 Battery Replacement: stap 5, afbeelding 2 van 3 NexiGo NS32 Battery Replacement: stap 5, afbeelding 3 van 3
    • Lift the battery up and out.
    • Take care not to bend or puncture the battery as you remove it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Matthew Nguyen
235 Reputatie
1 Handleiding geschreven
1Gids Commentaar
Do you know what model battery I would need to buy to replace the original?
Jack Dunne - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 400
