Ga door naar hoofdinhoud
Netgear WGR614v9 Capacitor Replacement
Wat je nodig hebt
  1. Netgear WGR614v9 Capacitor Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Capacitor Replacement: stap 2, afbeelding 1 van 2 Netgear WGR614v9 Capacitor Replacement: stap 2, afbeelding 2 van 2
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Capacitor Replacement: stap 3, afbeelding 1 van 2 Netgear WGR614v9 Capacitor Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Capacitor Replacement: stap 4, afbeelding 1 van 1
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Capacitor Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Capacitor Replacement: stap 6, afbeelding 1 van 2 Netgear WGR614v9 Capacitor Replacement: stap 6, afbeelding 2 van 2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. Netgear WGR614v9 Capacitor Replacement, Capacitor: stap 7, afbeelding 1 van 2 Netgear WGR614v9 Capacitor Replacement, Capacitor: stap 7, afbeelding 2 van 2
    • Rotate the motherboard so that the top is facing up.
    • Set the motherboard on a flat clean surface.
  8. Netgear WGR614v9 Capacitor Replacement: stap 8, afbeelding 1 van 2 Netgear WGR614v9 Capacitor Replacement: stap 8, afbeelding 2 van 2
    • The capacitor can be found at the location shown.
  9. Netgear WGR614v9 Capacitor Replacement: stap 9, afbeelding 1 van 2 Netgear WGR614v9 Capacitor Replacement: stap 9, afbeelding 2 van 2
    • Rotate the motherboard so that the bottom is facing up.
    • Locate the two soldered contacts of the capacitor.
  10. Netgear WGR614v9 Capacitor Replacement: stap 10, afbeelding 1 van 3 Netgear WGR614v9 Capacitor Replacement: stap 10, afbeelding 2 van 3 Netgear WGR614v9 Capacitor Replacement: stap 10, afbeelding 3 van 3
    • Rotate the motherboard 180 degrees.
    • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
    • Refer to this link for proper de-soldering and soldering techniques.
    • Pull the capacitor from the other side of the circuit board once the solder is liquified.
    • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kyle Moore
95 Reputatie
1 Handleiding geschreven
Cal Poly, Team 21-24, Maness Fall 2011 Lid van Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Leden
11 handleidingen geschreven
Één opmerking
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 3,213
