Ga door naar hoofdinhoud
Nest Cam Wi-Fi Cable Replacement
Wat je nodig hebt
  1. Nest Cam Wi-Fi Cable Replacement, Wi-Fi Cable: stap 1, afbeelding 1 van 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Wi-Fi Cable Replacement: stap 2, afbeelding 1 van 3 Nest Cam Wi-Fi Cable Replacement: stap 2, afbeelding 2 van 3 Nest Cam Wi-Fi Cable Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Wi-Fi Cable Replacement: stap 3, afbeelding 1 van 3 Nest Cam Wi-Fi Cable Replacement: stap 3, afbeelding 2 van 3 Nest Cam Wi-Fi Cable Replacement: stap 3, afbeelding 3 van 3
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Wi-Fi Cable Replacement: stap 4, afbeelding 1 van 1
    • Using a soldering iron, melt away the base of the Wi-Fi cable until it can be removed. Use this guild for assistance with soldering.
    • Ensure when you solder the new cable back on that all connector ends are positioned correctly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jade Weiss
662 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-1, Leahy Spring 2016 Lid van USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Leden
10 handleidingen geschreven
2 opmerkingen
I have broken the cable attached to Nest camera. Can you get replacement or repair the lead? Hope i haven't got to buy a new camera
Kerrie Davies - Antwoord
I have broken lead attached to Nest camera. Can i get a replacement or repair it? Hope i havent got to buy a new camera.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 4,331
