Inleiding
You will only need a screwdriver to take apart this Nerf gun and access the loading spring. Also obtain a new spring if needed.
Wat je nodig hebt
Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
Remove the twelve #00 1 cm Phillips screws.
Rotate the gun so that the front is facing you to remove the final screw.
Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
Één andere persoon heeft deze handleiding voltooid.
