Ga door naar hoofdinhoud
Nerf Vortex Vigilon Clip Attachment Replacement
Wat je nodig hebt
    1. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the slide screws: stap 1, afbeelding 1 van 1
      • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
      • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
      • Both sides of the slide will come off when the screws are removed.
      Vraag FixBot
      Voeg opmerking toe
    2. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the slide pieces: stap 2, afbeelding 1 van 1
      • Lift both slide pieces off of the gun.
      Vraag FixBot
      Voeg opmerking toe
    1. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outer screws: stap 3, afbeelding 1 van 2 Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outer screws: stap 3, afbeelding 2 van 2
      • Remove the twelve #00 1 cm Phillips screws.
      • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
      • Rotate the gun so that the front is facing you to remove the final screw.
      Vraag FixBot
      Voeg opmerking toe
    2. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outside cover: stap 4, afbeelding 1 van 1
      • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
      • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
      • The magazine will slide down automatically as you remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the clip attachment: stap 5, afbeelding 1 van 2 Nerf Vortex Vigilon Clip Attachment Replacement, Removing the clip attachment: stap 5, afbeelding 2 van 2
      • At the top left area of the gun, lift the clip towards you, and it will easily slide out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cara Pew
932 Reputatie
7 handleidingen geschreven
Cal Poly, Team 13-6, Forte Fall 2014 Lid van Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 1,489
