Ga door naar hoofdinhoud
Nerf Recon CS-6 Trigger Replacement
Wat je nodig hebt
    1. Nerf Recon CS-6 Trigger Replacement, Remove Magazine: stap 1, afbeelding 1 van 1
      • Skip this step if magazine is already removed.
      • Pull slide back.
      • Pull backwards on release buttons and slide magazine out.
      • Push slide back forward and pull trigger.
      Vraag FixBot
      Voeg opmerking toe
    2. Nerf Recon CS-6 Trigger Replacement, Remove Visible Screws: stap 2, afbeelding 1 van 1
      • Use the Phillips #0 Screwdriver to remove these 9 screws.
      • All screws marked in red are 9.6 mm Phillips #0 screws.
      • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
      Vraag FixBot
      Voeg opmerking toe
    3. Nerf Recon CS-6 Trigger Replacement, Remove Hidden Screws: stap 3, afbeelding 1 van 2 Nerf Recon CS-6 Trigger Replacement, Remove Hidden Screws: stap 3, afbeelding 2 van 2
      • Pull slide back to reveal more screws.
      • Remove these 2 screws.
      • Push slide forward.
      • Pull trigger to release compression of the main spring.
      • Screws are 9.6 mm Phillips #0.
      • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
      Vraag FixBot
      Voeg opmerking toe
    4. Nerf Recon CS-6 Trigger Replacement, Remove Plunger Cap: stap 4, afbeelding 1 van 1
      • Remove the screws on the plunger cap.
      • Tug the plunger cap off.
      Vraag FixBot
      Voeg opmerking toe
    5. Nerf Recon CS-6 Trigger Replacement, Remove Slide Screws: stap 5, afbeelding 1 van 1
      • Remove the 2 screws on the slide.
      • Hold the two halves of the gun together to prevent any springs from launching out.
      Vraag FixBot
      Voeg opmerking toe
    6. Nerf Recon CS-6 Trigger Replacement, Split the Gun in Half: stap 6, afbeelding 1 van 2 Nerf Recon CS-6 Trigger Replacement, Split the Gun in Half: stap 6, afbeelding 2 van 2
      • Pull the gun apart at the middle seam.
      • Watch for any springs that might launch out.
      Vraag FixBot
      Voeg opmerking toe
    1. Nerf Recon CS-6 Trigger Replacement, Remove Trigger: stap 7, afbeelding 1 van 1
      • Lift trigger up out of the gun.
      • From here, the trigger or the trigger spring can be replaced.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Pam Ruffner
1.002 Reputatie
3 handleidingen geschreven
Baylor, Team 8-14, Williams Fall 2014 Lid van Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 41
Altijd: 4,456
