Ga door naar hoofdinhoud
Nerf Recon CS-6 Plunger Replacement
Wat je nodig hebt
  1. Nerf Recon CS-6 Plunger Replacement, Remove Magazine: stap 1, afbeelding 1 van 1
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
    Vraag FixBot
    Voeg opmerking toe
  2. Nerf Recon CS-6 Plunger Replacement, Remove Visible Screws: stap 2, afbeelding 1 van 1
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
    Vraag FixBot
    Voeg opmerking toe
  3. Nerf Recon CS-6 Plunger Replacement, Remove Hidden Screws: stap 3, afbeelding 1 van 2 Nerf Recon CS-6 Plunger Replacement, Remove Hidden Screws: stap 3, afbeelding 2 van 2
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
    Vraag FixBot
    Voeg opmerking toe
  4. Nerf Recon CS-6 Plunger Replacement, Remove Plunger Cap: stap 4, afbeelding 1 van 1
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
    Vraag FixBot
    Voeg opmerking toe
  5. Nerf Recon CS-6 Plunger Replacement, Remove Slide Screws: stap 5, afbeelding 1 van 1
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
    Vraag FixBot
    Voeg opmerking toe
  6. Nerf Recon CS-6 Plunger Replacement, Split the Gun in Half: stap 6, afbeelding 1 van 2 Nerf Recon CS-6 Plunger Replacement, Split the Gun in Half: stap 6, afbeelding 2 van 2
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
    Vraag FixBot
    Voeg opmerking toe
  7. Nerf Recon CS-6 Plunger Replacement, Remove Spring: stap 7, afbeelding 1 van 2 Nerf Recon CS-6 Plunger Replacement, Remove Spring: stap 7, afbeelding 2 van 2
    • Pull the spring out the back of the gun.
    Vraag FixBot
    Voeg opmerking toe
  8. Nerf Recon CS-6 Plunger Replacement, Removing Plunger Guide: stap 8, afbeelding 1 van 1
    • Lift the plunger guide straight up out of the gun.
    Vraag FixBot
    Voeg opmerking toe
  9. Nerf Recon CS-6 Plunger Replacement, Remove Plunger: stap 9, afbeelding 1 van 1
    • Pull the plunger out the back of the gun off of the inner piece.
    Vraag FixBot
    Voeg opmerking toe
  10. Nerf Recon CS-6 Plunger Replacement, Remove  Other Half of Plunger: stap 10, afbeelding 1 van 1
    • Pull the remaining half of the plunger out the back of the gun.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Asad Qureshi
595 Reputatie
3 handleidingen geschreven
Baylor, Team 8-14, Williams Fall 2014 Lid van Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Leden
6 handleidingen geschreven
1Gids Commentaar
Do you know anywhere that you can buy a replacement plunger? Thanks
Angela Hirschi - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 39
Altijd: 5,249
