Inleiding
In cases where the unloading button fails to release the loading barrel, you may need to open your Strongarm up for inspection. Follow these steps to verify the button is in proper working order.
Wat je nodig hebt
Look inside the top cover of the blaster and locate the tab extending from the unloading button. It shouldn't be too hard to find as pictured since it will be the only orange piece.
Inspect the button's location for signs of debris impeding its operation. Replace if necessary.
Ensure the unloading button has a 45 degree angle contact surface.
