Ga door naar hoofdinhoud
Nerf N-Strike Elite Retaliator Trigger Spring Replacement
Wat je nodig hebt
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Case Disassembly: stap 1, afbeelding 1 van 1
      • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
      Vraag FixBot
      Voeg opmerking toe
    2. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: stap 2, afbeelding 1 van 1
      • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
      Vraag FixBot
      Voeg opmerking toe
    3. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: stap 3, afbeelding 1 van 1
      • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
      Vraag FixBot
      Voeg opmerking toe
    4. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: stap 4, afbeelding 1 van 2 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: stap 4, afbeelding 2 van 2
      • Remove the stock attachment point by removing the two 8mm Phillips head screws.
      Vraag FixBot
      Voeg opmerking toe
    5. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: stap 5, afbeelding 1 van 2 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: stap 5, afbeelding 2 van 2
      • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
      • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
      • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
      Vraag FixBot
      Voeg opmerking toe
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: stap 6, afbeelding 1 van 3 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: stap 6, afbeelding 2 van 3 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: stap 6, afbeelding 3 van 3
      • Carefully pull the orange trigger upward and backward to remove it from the blaster.
      • This component is under spring pressure. Wear appropriate personal protective equipment to shield your eyes.
      • Remove the spring from the rear of the trigger.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
ericharman
1.440 Reputatie
5 handleidingen geschreven
1Gids Commentaar
ok, taken the spring out. now what?
Kelvin Mead - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 51
Altijd: 10,171
