Ga door naar hoofdinhoud
Neato Botvac D75 LCD Screen Replacement
Wat je nodig hebt
    1. Neato Botvac D75 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 3 Neato Botvac D75 LCD Screen Replacement, Battery: stap 1, afbeelding 2 van 3 Neato Botvac D75 LCD Screen Replacement, Battery: stap 1, afbeelding 3 van 3
      • Use Phillips #1 screwdriver to unscrew the two bottom cover screws
      • Be careful, the screws are self-retained on the cover itself and does not come off the battery cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Neato Botvac D75 LCD Screen Replacement: stap 2, afbeelding 1 van 3 Neato Botvac D75 LCD Screen Replacement: stap 2, afbeelding 2 van 3 Neato Botvac D75 LCD Screen Replacement: stap 2, afbeelding 3 van 3
      • Lift battery cover out.
      Vraag FixBot
      Voeg opmerking toe
    3. Neato Botvac D75 LCD Screen Replacement: stap 3, afbeelding 1 van 3 Neato Botvac D75 LCD Screen Replacement: stap 3, afbeelding 2 van 3 Neato Botvac D75 LCD Screen Replacement: stap 3, afbeelding 3 van 3
      • Be careful when taking out the battery. Do not pull on the wires or battery trying to get the connector out.
      • The cord has prongs on it that are a little difficult to get out. Use a flathead screwdriver to press the release tab on the connector to remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. Neato Botvac D75 LCD Screen Replacement, Brushes: stap 4, afbeelding 1 van 3 Neato Botvac D75 LCD Screen Replacement, Brushes: stap 4, afbeelding 2 van 3 Neato Botvac D75 LCD Screen Replacement, Brushes: stap 4, afbeelding 3 van 3
      • To remove the rotary brush simply grasp it firmly and pull it off.
      Vraag FixBot
      Voeg opmerking toe
    2. Neato Botvac D75 LCD Screen Replacement: stap 5, afbeelding 1 van 3 Neato Botvac D75 LCD Screen Replacement: stap 5, afbeelding 2 van 3 Neato Botvac D75 LCD Screen Replacement: stap 5, afbeelding 3 van 3
      • Once you have everything out get the plastic opening tool and pry open the large black plastic piece.
      • With a little force it should come out.
      • The boxes show you were the clips are that hold this piece
      Vraag FixBot
      Voeg opmerking toe
    3. Neato Botvac D75 LCD Screen Replacement: stap 6, afbeelding 1 van 1
      • Once the black piece has been taken out, the brush just comes out easily.
      Vraag FixBot
      Voeg opmerking toe
    1. Neato Botvac D75 LCD Screen Replacement, LCD Screen: stap 7, afbeelding 1 van 2 Neato Botvac D75 LCD Screen Replacement, LCD Screen: stap 7, afbeelding 2 van 2
      • Firmly grasp the back cover and pull away from the Botvac one side at a time.
      • Removing the cover will expose two 1.3mm T10 screws that must be removed to separate the cover halves.
      Vraag FixBot
      Voeg opmerking toe
    2. Neato Botvac D75 LCD Screen Replacement: stap 8, afbeelding 1 van 2 Neato Botvac D75 LCD Screen Replacement: stap 8, afbeelding 2 van 2
      • Remove these two 13mm T10 screws. You will need to use the extension in your tool set since they are deep in the casting.
      Vraag FixBot
      Voeg opmerking toe
    3. Neato Botvac D75 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Neato Botvac D75 LCD Screen Replacement: stap 9, afbeelding 2 van 2
      • Eight 13mm T10 screws on the underside of the Botvac hold the casing together. These screws are not self-retained so make sure that you don’t lose them in the disassembly process.
      Vraag FixBot
      Voeg opmerking toe
    4. Neato Botvac D75 LCD Screen Replacement: stap 10, afbeelding 1 van 3 Neato Botvac D75 LCD Screen Replacement: stap 10, afbeelding 2 van 3 Neato Botvac D75 LCD Screen Replacement: stap 10, afbeelding 3 van 3
      • The screws pictured here on either side of the Botvac require the extension in your tool set to be removed.
      Vraag FixBot
      Voeg opmerking toe
    5. Neato Botvac D75 LCD Screen Replacement: stap 11, afbeelding 1 van 2 Neato Botvac D75 LCD Screen Replacement: stap 11, afbeelding 2 van 2
      • On the back of the Botvac there are two retaining tabs that must be pressed to be released.
      • With the tabs released the top and bottom cover halves can be separated.
      Vraag FixBot
      Voeg opmerking toe
    6. Neato Botvac D75 LCD Screen Replacement: stap 12, afbeelding 1 van 3 Neato Botvac D75 LCD Screen Replacement: stap 12, afbeelding 2 van 3 Neato Botvac D75 LCD Screen Replacement: stap 12, afbeelding 3 van 3
      • Carefully lift the top cover of the Botvac. On the right side of the Botvac is where you'll find the LCD screen connector to the motherboard. Carefully pull on the connector to disconnect it from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    7. Neato Botvac D75 LCD Screen Replacement: stap 13, afbeelding 1 van 3 Neato Botvac D75 LCD Screen Replacement: stap 13, afbeelding 2 van 3 Neato Botvac D75 LCD Screen Replacement: stap 13, afbeelding 3 van 3
      • There are two 0.5cm #1 Phillips screws holding the LCD screen to the top cover. Remove these screws to lift screen off the cover.
      Vraag FixBot
      Voeg opmerking toe
    8. Neato Botvac D75 LCD Screen Replacement: stap 14, afbeelding 1 van 3 Neato Botvac D75 LCD Screen Replacement: stap 14, afbeelding 2 van 3 Neato Botvac D75 LCD Screen Replacement: stap 14, afbeelding 3 van 3
      • With the two screws removed you may lift the screen off the cover. Carefully remove the connector from the screen by pulling on the connector.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Juan Cornejo
606 Reputatie
5 handleidingen geschreven
USF Tampa, Team S6-G5, Lacy Spring 2017 Lid van USF Tampa, Team S6-G5, Lacy Spring 2017
USFT-LACY-S17S6G5
4 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 3,406
