Ga door naar hoofdinhoud
Neato Botvac D75 Battery Replacement
Wat je nodig hebt
    1. Neato Botvac D75 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Neato Botvac D75 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Neato Botvac D75 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
      • Use Phillips #1 screwdriver to unscrew the two bottom cover screws
      • Be careful, the screws are self-retained on the cover itself and does not come off the battery cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Neato Botvac D75 Battery Replacement: stap 2, afbeelding 1 van 3 Neato Botvac D75 Battery Replacement: stap 2, afbeelding 2 van 3 Neato Botvac D75 Battery Replacement: stap 2, afbeelding 3 van 3
      • Lift battery cover out.
      Vraag FixBot
      Voeg opmerking toe
    3. Neato Botvac D75 Battery Replacement: stap 3, afbeelding 1 van 3 Neato Botvac D75 Battery Replacement: stap 3, afbeelding 2 van 3 Neato Botvac D75 Battery Replacement: stap 3, afbeelding 3 van 3
      • Be careful when taking out the battery. Do not pull on the wires or battery trying to get the connector out.
      • The cord has prongs on it that are a little difficult to get out. Use a flathead screwdriver to press the release tab on the connector to remove it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Juan Cornejo
606 Reputatie
5 handleidingen geschreven
USF Tampa, Team S6-G5, Lacy Spring 2017 Lid van USF Tampa, Team S6-G5, Lacy Spring 2017
USFT-LACY-S17S6G5
4 Leden
15 handleidingen geschreven
1Gids Commentaar
Thanks for the tuto.
an additionnal info when having a battery issue, is to the reset to new battery. enter the menu, then help, and chose new battery.
it seems the neato system is set for planned obsolescence… unfortunatly for customers….
so I did it because battery stayed empty while plugged and switch found ok . And new my botvac is ok, like new!!
Nom - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 49
Altijd: 2,999
