Ga door naar hoofdinhoud
Neato Botvac 80 Wheel Replacement
Wat je nodig hebt
    1. Neato Botvac 80 Wheel Replacement, Rear Bumper: stap 1, afbeelding 1 van 1
      • Grab the rear bumper with both hands on either side.
      Vraag FixBot
      Voeg opmerking toe
    2. Neato Botvac 80 Wheel Replacement: stap 2, afbeelding 1 van 1
      • Pull the left and right sides away from the machine to unclip the bumper. This requires that you bend the plastic a little bit. Unclip one side a little bit and allow the prong to rest on the side of the machine. Then unclip the other side and pull off the bumper parallel to both sides
      Vraag FixBot
      Voeg opmerking toe
    1. Neato Botvac 80 Wheel Replacement, Top Face Panel: stap 3, afbeelding 1 van 2 Neato Botvac 80 Wheel Replacement, Top Face Panel: stap 3, afbeelding 2 van 2
      • Looking from above, remove the two 11mm screws with a torx T10 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Neato Botvac 80 Wheel Replacement: stap 4, afbeelding 1 van 1
      • Begin by placing the robot on it's back and removing the six 11m screws using a Torx T10 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Neato Botvac 80 Wheel Replacement: stap 5, afbeelding 1 van 3 Neato Botvac 80 Wheel Replacement: stap 5, afbeelding 2 van 3 Neato Botvac 80 Wheel Replacement: stap 5, afbeelding 3 van 3
      • To remove the top, you must press in both of the clamps at the same time and push upwards.
      • When removing the top, before you can completely take it off you must unplug the LCD power cable from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Neato Botvac 80 Wheel Replacement, Wheels: stap 6, afbeelding 1 van 3 Neato Botvac 80 Wheel Replacement, Wheels: stap 6, afbeelding 2 van 3 Neato Botvac 80 Wheel Replacement, Wheels: stap 6, afbeelding 3 van 3
      • Locate the screws that mount the wheel extensions on the Botvac.
      • Unscrew the four 11mm screws and bolts indicated to remove the frame.
      • The metallic weight (as shown) does not require the removal of any screws. However, make sure to complete this before proceeding.
      Vraag FixBot
      Voeg opmerking toe
    2. Neato Botvac 80 Wheel Replacement: stap 7, afbeelding 1 van 2 Neato Botvac 80 Wheel Replacement: stap 7, afbeelding 2 van 2
      • Gently lift the frame holding the laser. This will free the wheels from their casing.
      • Remove the wheel's wires that are attached to the motherboard.
      • Once removed, you may now free the wheels.
      Vraag FixBot
      Voeg opmerking toe
    3. Neato Botvac 80 Wheel Replacement: stap 8, afbeelding 1 van 3 Neato Botvac 80 Wheel Replacement: stap 8, afbeelding 2 van 3 Neato Botvac 80 Wheel Replacement: stap 8, afbeelding 3 van 3
      • Remove the wheel usings the T15, or similar, attachment to remove the 32.5mm screw.
      • Finally, just grab and separate the tire from its axle.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Brandon Blank
675 Reputatie
5 handleidingen geschreven
USF Tampa, Team 17-5, Blackwell Spring 2017 Lid van USF Tampa, Team 17-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G5
3 Leden
18 handleidingen geschreven
8Gids Commentaar
After this fix, it just says to put it in the floor. Is there a sensor or withat I may have missed connecting?
Sandra Me - Antwoord Deel
are left and right rear wheels identical parts? can one just replace the wheels and not the motors? I have loose ratcheting in one of the rear wheels. the D80 won’t back up correctly and stalls at each chair.
Dennis Abramsohn - Antwoord Deel
I have a Neato D7 and I am replacing the wheels. I have pulled it apart and mistakenly didn’t take a picture prior to disassembling the same area you did with the 80. Do you at least have a diagram of the D7 that I could use to re-assemble? I am particularly concerned about where the springs and a circular piece connected to circuit board (labeled 8015W) is placed.
Thanks
cornishpd - Antwoord Deel
The tread on my botvac 80 is gone on 1 back wheel. Motor seems to still work good. Can you tell me how to get a replacement wheel? Have looked on amazon and ebay. Any help will be appreciated. Tammy
Lucky charms LeFlohic - Antwoord Deel
Taking apart and assembly is the easy part. Finding spares however… Got a worn down drive gear, that’s it. The rest of the machine seems just fine. So a $4-500 gadget is broken just because I can’t find a small plastic gear replacement that shouldn’t be more than a few bucks. Stupid.
Jens B. - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 9,938
